Super Victor map sensor location
Old 06-08-2015, 03:15 PM
edub80's Avatar
Default Super Victor map sensor location
Doing an intake swap to a super Victor... Have a vacuum port on passenger side of intake plenum.. can I just run a barb fitting with about an 8" hose length to the map sensor using a hose clamp to keep the hose on the map sensor?.. Will that give me a correct map reading?
Old 06-08-2015, 05:24 PM
Zmg00camaross's Avatar
What throttle body are you running? You can run to the barb fitting though shorter the hose the better IMO
Old 06-08-2015, 05:34 PM
red_00z28's Avatar
Like this.
Old 06-08-2015, 05:46 PM
edub80's Avatar
Fast 4150.. so use the shortest hose possible?
Old 06-08-2015, 05:47 PM
edub80's Avatar
Originally Posted by red_00z28
Like this.
Ok so short as I can
Old 06-08-2015, 06:11 PM
edub80's Avatar
So would it cause any issues if you ran it with 8-12" hose? Just curious.. that's how I have it now but it will be changed to be short
Old 06-08-2015, 06:24 PM
red_00z28's Avatar
Do you have hp tuners or any scanner where you can log the map readings? If you do you could do a comparison to see of the longer hose make a difference.
Old 06-08-2015, 06:26 PM
Isn't there tiny vaccum ports on the throttle body? Would be under the throttle blades obviously.
Old 06-08-2015, 06:30 PM
red_00z28's Avatar
Yea there are 2 small ones(1/8th" I believe) and one 1/4". I used one of the small ones for the vacuum for the hvac and the larger one for the catch can routing. Using the port on the side of the intake worked good for me. I also re routed the iac and tps sensor wires to come up from under the intake.
Old 06-08-2015, 06:49 PM
edub80's Avatar
Yes I do.. and I will definitely see if there is a difference
Old 06-08-2015, 06:53 PM
edub80's Avatar
Yes there are.. mine are plugged at the moment but will be hooking my hvac and catch can up to those two
Yep your right.. as of right now I have my map going in to the side of intake with about an 8" line but will be cutting it to make it like yours...
I'm having issues with the SD tuning right now so( going lean as he'll when I get into PE for half a sec and then goes rich then I let out and it stays rich for like 10-15 secs) I'm kinda at a loss on that issue
Old 06-08-2015, 06:55 PM
edub80's Avatar
My VE table from like 3600 up is lower than a stock VE table..
Old 06-08-2015, 08:28 PM
I am guessing manual brakes.
Old 06-08-2015, 08:38 PM
edub80's Avatar
Yes sir
Old 06-09-2015, 07:42 AM
Well then I would definetly use the port on the manifold. Super Vic on my car and haven't done manual brakes yet so guess I am going to use one of those little ports on the throttle body.
Old 06-09-2015, 08:17 AM
edub80's Avatar
If I remember correctly.. Ur a tuner right? Shane?.. do u have any idea on my sd tune problems I posted in this thread? U ever seen that before? Lol
Old 06-09-2015, 01:09 PM
I am not Shane, but Shane is my tuner, he is 04blackgmc.
Old 06-09-2015, 01:59 PM
edub80's Avatar
Oh ok lol
Old 06-11-2015, 08:49 PM
70LS1Nova's Avatar
Drill a hole in your intake and stick it in the hole. Just like it was from GM.
Old 06-11-2015, 09:55 PM
HISS's Avatar
Thats a great idea. Wonder if you could drill a hole under the plenum below where the throttle body sits and mount it under the intake so it looks super clean.
Quick Reply: Super Victor map sensor location
