ON3 Hot side quality.
I installed this kit a few years ago but didn't get to drive it until last summer when I started tuning it. Well during the short time I was driving it my relief spring in my oil pump was sticking so everytime I made a pull I would loose oil pressure. During one of the few pulls I did I lost boost at the top of second and figured I blew a pipe off. Drove it back home and the pipes were good. Pulled the filter off and the turbo wouldn't spin. Figured the guts were toast. Well just got back in the states last week and started working on the car again. I took the turbo apart today and was suprised what I had found. Took the compressor cover off and it is mint. Took the turbine off and one little corner of one blade is bent but it doesn't look like anything went through it. Loot in the turbine housing and find 2 pieces MIG welding stuck in the scroll. I am thinking it came from where they welded the wastegate pipe to the crossover.
No Ac setup. I ended up not using thier manifolds the kit came with. They were Dorman repops and had all the EGR and emission fittings in them. I didn't want to risk any leaks so i threw those in the trash. Also it was hard as hell to get the back bolt in for the crossover with the kmember in the car. I chose to use stock truck manifolds and left the studs in and just notched the crap out of the stock kmember to allow access. It is much easier now to R&R the crossover and I have no leaks. Also spent a lot of time getting the cold side to fit properly. Lots of triming where the cold side comes through By the drivers side fuse box. Also spent extra time adjusting those pipes so the silicone hoses wouldn't get a hole rubbed in them. Takes time to get that adjusted where nothing rubbed. Intercooler mounting is a joke. I will still say it's a decent kit for the money. Just not what i thought it was going to be like after reading a build thread on here...
You could have bought one from dorman or used a GM truck manifold.
https://m.summitracing.com/parts/rnb-674-522
https://m.summitracing.com/parts/rnb-674-732
my buddy and i put an on3 kit, 76mm ceramic ball bearing on3 turbo in his 00 camaro 3-4 months ago, been running 4.5psi makin 442RWHP. 162,xxx miles on stock 5.7 when installed.
Just turned it up to 8.5psi last week, made 548RWHP, 530LB/TORQUE. Car is now at 169,xxx miles
Honestly, we couldnt be happier with the quality of the piping, hot and cold side. For the money, its hard to beat. Runnin on3 WG, BOV, Fuelpump, injectors. Its all on3 with no issues yet.
Now were not expecting the on3 turbo to last forever but if it makes 12k miles i feel the money was well spent.
ive seen so many cracked manifolds and crossovers on various ls mustang threads. its cheap Chinese stuff. there is a reason why a whole kit is what 1500? you get what you pay for every time. I think they use 16ga stainless which is way way to damn this for hot parts
