Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
Jetting Help
Old 10-24-2016, 08:32 AM
CaptSchwag's Avatar
Default Jetting Help
Howdy
I put a stock 5.3 in my fox and I need some help or some guidance on the jetting size to get started. I opened up the carb to replace the gaskets and to get a peak at the jets and power valve. I am not new to carbs and have had several but I am new to these lsx motors.
Current Setup
Mighty Demon 750
74/84
Primary Power Valve is a 55
Rear Power Valve is a block
Also, the jets are stuck or really in there. Any tricks to removing them with out breaking them? Not sure if those tools are worth the money.
Thanks again.
Old 10-24-2016, 10:21 AM
LQ4BU's Avatar
The jets shouldnt be that tight, unless someone cranked them down. I use a flat screwdriver with a thick tip and have never had a problem. There are a handful of jet-removal tools available for under $20 though.
What is causing you to want to change the jets, are the plugs rich/lean, is it not running right?
Do you have a vacuum gauge? Its a very valuable tool that can help you set your idle mixture, and you can use it to determine what type of power valve best suits your setup.
As far as choosing jets, you will need to either use a air/fuel gauge or read the spark plugs to see whats going on inside the engine.
Videos below are from Holley but its the same process with a Demon
Hot to set idle mixture
How to choose power valve
Old 10-24-2016, 10:27 AM
CaptSchwag's Avatar
5.3 is bone stock out side of the intake. Its a Holley single plane.
I haven't fired or started the car yet but will by weeks end. 74 / 84 seemed pretty stout compared to what I have had in the past. Never had to get that high on a sbf with heads and cam. I searched around here first and a 750 with those jet sizes are 6.0 with a cam.
I have had to change the jets many times in the past on several cars and have never had them to were I can get them to budge. Ended up chipping on off... Thats what i get for a CL deal.
Old 10-24-2016, 09:09 PM
Greg.H's Avatar
I would invest in a vacuum gauge and a wideband A/F meter. They will make precise tuning 1,000,000 times easier.
With a stock cam 5.3, that power valve is only going to open at WOT. I would use a 10.5 minimum (it's the heaviest one they sell) if you are going to keep that cam, or something similar in there. I have a 650 DP on my stock 5.3 and it pulls 23" Hg at idle; I made a custom 16" power valve for it, Could probably do better with 18.
I assume you are changing the cam, hence the 750 and the single plane manifold? Are you tuning for best mileage/driveability/performance or is this a track only car?
Old 10-25-2016, 06:56 AM
CaptSchwag's Avatar
Thanks Greg for that info. I have been looking at Innovations wide band setup to get it dialed in for the long run.
This is a track only car and a cam & nitrous are coming soon. Left it stock for now just to get the swap going and work some bugs out.
Ran across these jets and thought they were large for this motor. I am mostly curious what others are running on their stock 5.3's.
Quick Reply: Jetting Help
