Tried my best fixing the slip-on exhaust header. What are my other options?
I want to stay under $350 when purchasing new headers.
Current set-up are Mac headers + Y-pipe + gutted cat + Magnaflow exhaust.
I like the no drone set-up and would like to keep it but the exhaust leak sucks and I don't want to put any more effort in fixing it. I'd rather get new headers. What do you guys recommend?
Village Troll
I have Hooker LT's where the #1 primary is a slip fit and very loose. Tried sealing it with Ultra Copper and also JB Weld. It would hold for a minute and then blow out. I have a band clamp on it now I put on several years ago. Still leaks. I just deal with it.
This stuff is used on slip joints, not flanges. Basically, you just run a bead on the ID of the larger tube and OD of the smaller tube, slide it together, then clamp it down with a band clamp.
Oops, forgot to update on this:
I did buy the Walker acousti-seal as pictured but I can't find any band clamps of my size and when I ask people locally, they pretend to never heard of such thing. I bought a heavy duty exhaust clamp and it still leaks. Do I need anything else?
1.5 means that it can clamp down piping as small as 1.5. This should work just fine with your 1-5/8 primaries, but I would keep checking for a smooth band if possible.
