Fast 102 intake
Fast 102 intake
I have a 2004 GTO with an LS1 and can get a great deal on a fast 102 intake. What all do I need to do for the installation of this? Can I use the stock injectors or fuel rails?
I used stock style injectors, different orings from FAST, and a billet fast rail. You will probably have to grind your water pump a bit for clearance. There are several threads that have almost every issue in them that people have coke across
You only need to grind the pump if you're using the big 102tb. A 92 or 95 does not require this. You will need the ls2 style rail or the fast billet rails and if using the stock thin ls1 style injectors you need the fat lower oring since the holes in the fast intake are made for larger injectors.
