Easiest way to wire up a transbrake button
Old 02-24-2017, 11:55 AM
Game ova's Avatar
Default Easiest way to wire up a transbrake button
I'm falling on the sword here, when it comes to wiring I'm for the most part completely lost. Can someone explain the easiest way to go about this. This will be without a relay.
Old 02-24-2017, 02:25 PM
Firebirdmuscle's Avatar
12v activated I supposed?
Old 02-24-2017, 02:27 PM
Game ova's Avatar
it is. Just not sure how to run the wires.
Old 02-24-2017, 02:32 PM
On your button you should have a small pigtail. Run trans brake wire to one of the leads off button, then run a 12v source to the other lead off of the button. When you press button it will then close the circuit and send 12v to ththe trans brake. I would probably use a ignition 12v source, ( switched )
Old 02-24-2017, 04:51 PM
Nostang's Avatar
You can run a relay and a master switch so you can only activate the t-brake when you want to. The wiring should go like this off the relay.
85-keyed hot 12V
86-to master switch then from master switch to ground.(this will turn on the relay to get the trans brake ready for use).
30-fused hot 12V (run a fuse off of 12v source)
87-to one wire of t-brake to your t-brake switch. The other wire off your 12v switch will go to ground.
Or you can run a fused 12v to one wire on your t-brake then your other wire off your t-brake to a master switch then to your t-brake switch. It depends on if you prefer to run a relay or not.
Old 02-25-2017, 06:41 AM
Game ova's Avatar
Thanks man.
Old 02-25-2017, 08:07 AM
Dimeomboost's Avatar
I jumped a relay off in my fuse box and ran the wire to the solenoid hot wire and then solenoid ground wire grounded solenoid to frame and activate relay wire to button and button ground to frame?? Works great
Old 02-27-2017, 07:36 AM
LS1Tech Sponsor
FTICONVERTERS's Avatar
Make sure the button you use a normally open switch and not a normally closed switch.
and don't forget to ground the solenoid as well
__________________
FTI COMPETITION CONVERTERS AND TRANSMISSIONS
"IT'S NOT CHEATING, IT'S THE COMPETITIVE EDGE."
1-866-726-8358
info@ftiperformance.com
FTIPerformance.com
FTI Converter build sheet
Old 02-27-2017, 02:09 PM
Game ova's Avatar
Thanks for all the help guys. I got it wired in and all is well now, just need to wire in the transmission cooler and the build/swap will be completed!
Quick Reply: Easiest way to wire up a transbrake button
