May get the ls1tech Darwin Award Of the day but...
for guys who went too small with their first fuel pump, why couldn't you use two different sized fuel pumps but have one kick on with a Hobbs switch? For example, Iln my 98 z28 i have a racetronix Hotwire setup with a 255lph pump. I just recently purchased an aeromotive 340lph stealth. Why couldn't they be ran together and successfully add more fuel together? I'm no expert on these cars "obviously " but the only issue I could see is one pump being overworked more so than the other . The same switch that engages my boost a pump, could be used to engage the 340lph pump once pressure drops so many psi , and allow me to make more power. Idk just food for thought as I'm sure a lot of people like me have wasted money on pumps like the 255lph and just assume when we upgrade it's useless unless running a dual 255lph setup .
Just my very humble opinion,,, but I've spent a lot of time a the track, I have a lot of friends that road race and I'm pretty good at keeping a car on track. Three things have cause more DNF's for me than any other.
1. Dual Fuel Pumps.
2. Crappy/Cheezy/sloppy electrical wiring.
3. Waiting till the last minute to prep the car (IE at the track on race day)
I really prefer a bigger single pump, bigger lines and a full return regulator. Electric high pressure pumps heat the fuel a lot. And the less time it spends in the lines in the engine bay the better. One problem is that with hydraulics the pump with the most power can dead head the other pump until demand get high enough that the head pressure equalizes on the output side of the pumps.
Your Mileage may vary...
1. Dual Fuel Pumps.
Most of the high powered cars in my area runna dual setup and a lot of them run dual baps "mostly cobras , Shelby and roush. It was just an idea so that people who didn't do t right first can still benefit from their old pump. I may attempt it and run it off of the bap switch , to engage the bap and a second pump .
1. Dual Fuel Pumps.
1. Dual Fuel Pumps.
I once had a guy show up at an 12 hour enduro, with a camaro with a regular NA small-block when he was backing it out of the trailer it was running like total crap,
When I asked him what was up he said, "Burnt Valve" , insert me looking like "WTF!" He says "we have a couple hours I figured we'd just change the valve"..
Now I could pull a head and replace the head in 2 hours with good help if there were $$$$ on the line but Do a valve? Possibly needing a grind and lord knows what in that motor when the head came off? Afraid I walked off into the sunset on that deal... They also forgot their rain tires and it was sprinkling at the track..
Damn, I wish more people understood the simple truth in your post. Dual pumps are actually MORE than twice as likely to fail than a single pump, bad wiring is the devil, and if you're lucky, last minute prep only ruins your day. It could easily blow a motor or kill you.
its not anything mechanical...just simple killing-floor statistics.
say your pump has a 1% chance to fail. add another pump. now each pump has a 1% chance to fail. add those together and it's 2%
i think the point he's making has to do with the installs rather than the pumps themselves.
You can do an aftermarket regulator and still use the stock feed line, and rails. You could just run either a return, or run a -8 feed and use your stock feed line as a return. You can do it for a couple hundred bucks.
I'm hooking the second pump to come on when the boost pressure switch sees 4lbs of boost. The only thing I don't like about that is like mentioned above there is a lot more room for error. Wiring, boost pressure switch failure, leak to boost pressure switch, ect ect. I watch the A/F gauge pretty closely, but I still would like to set a fail safe up somehow so if the a/f gauge goes lean it will warn me..
