Th400 First drive impression.
Old 02-26-2017, 01:23 AM
Game ova's Avatar
Default Th400 First drive impression.
So I finally finished swapping over to the Th400, got the brake wired up and went for a spin. The very first thing I noticed was how the converter felt, of course I didn't expect it to be tight....but not quite this loose either. So after driving for a while and stopping a few times to make sure there were no leaks, I figured it was time to see two things...one was is the tranny right....and two...how continuous power felt. The transmission is brutally firm on the1st to 2nd shift....going into 3rd...while there's no slip...its not quite as hard shifting. So how did it pull? Im hoping it's not because I haven't driven the car in 4 months...but the car feels retarded fast. I wasn't expecting it to feel like it did at ALL. So after cruising around town, I went home and got on the transbrake to see what the converter would actually stall to. It went 5200 and made almost 16psi instantly, here's the vid.
Old 02-26-2017, 06:51 AM
Project GatTagO's Avatar
Received 1,393 Likes on 879 Posts
The old saying for a TH400 is that they bang into second and glide into third...
Andrew
Old 02-26-2017, 08:06 AM
oscs's Avatar
Welcome to the fast car life. 6spd's are for the birds.
Old 02-26-2017, 08:10 AM
svslow's Avatar
Dang that converter is pretty loose. What is it?
Old 02-26-2017, 08:17 AM
Game ova's Avatar
Yea, I'm now beginning to wonder if my clutch was slipping when I still had the t56...car seems to pull MUCH harder now.
It's a PTC unit. I may have altered the stall speed (slightly) inadvertently, as I restricted the converter feed circuit to keep from killing my thrust bearings.
Old 02-26-2017, 08:35 AM
truckdoug's Avatar
you might try the regular viscosity hygard its a lil thicker than dex three, a lot thicker than dex 6
glad it all worked out. now what are you gonna do for a rear end?
Old 02-26-2017, 08:43 AM
Game ova's Avatar
I've seen some guys running that hyguard, seems to be some good stuff. I was wanting to do something like a Dana, but even with me building the tranny...it cost me quite a bit to do the swap. I had planned on having the rear end and tires by opening day.....bit its not going to happen. So unfortunately I'm going to have to rock the 10 bolt and these 315s for a little while longer.
Old 02-26-2017, 08:45 AM
Game ova's Avatar
And I'm sure these high gears I'm using might have a hand in how the converter feels too (2:73)
Old 02-26-2017, 09:24 AM
That_One_Person's Avatar
I'm not sure that they offer many turbo friendly gear sets for the Dana's. What would you go to? Like around a 3.08 or 3.23 if you swapped? Anyway sweet car and enjoy your newly found consistency.
Old 02-26-2017, 09:31 AM
Game ova's Avatar
Would likely stay around a 3.00, wouldn't want to go much lower than that. The only reason I say Dana is, supposedly they rob a little less power than a 9 inch. And thanks for the compliment.
Old 02-26-2017, 09:33 AM
Forcefed86's Avatar
What PTC unit is it? PN? What Ecu are you using? I limit my RPM to 3400-3600 or so on the brake. Once boost starts building it will fly past 5k as well without the 2-step active. I'm under 4% slip thru the traps at 6200rpm with the 9.5" PTC (14 stator). Trying to launch in 1st over 5k and 16ish lbs probably won't work well... may blow that rear end in a hurry too! Might try foot brake stuff till you can get a rearend under there. Also the taller you go on the gearing the weaker they get. A 2.7x is a pretty weak gear in general...even in a 9".
Good luck!
Old 02-26-2017, 09:48 AM
Game ova's Avatar
Good luck!
Lol, there will be no transbrake action with this current rear end. Only got on the brake to see what the converter would go...and how quickly boost came on line. And btw, I am NOT a fan of having to use the Transbrake to reverse, other than that I'm happy with the build. The part number is hard to read.
Old 02-26-2017, 10:29 AM
oscs's Avatar
Originally Posted by Game ova
Yea, I'm now beginning to wonder if my clutch was slipping when I still had the t56...car seems to pull MUCH harder now.It's a PTC unit. I may have altered the stall speed (slightly) inadvertently, as I restricted the converter feed circuit to keep from killing my thrust bearings.
I doubt it. Your just feeling what it's like to never get out of boost.
Old 02-26-2017, 10:34 AM
Game ova's Avatar
Old 02-26-2017, 10:37 AM
Game ova's Avatar
I always seemed to have higher rpm going through the traps than the math dictated by my gear ratio....just wondering if this is why.
Old 02-26-2017, 10:39 AM
truckdoug's Avatar
that really aint that bad looking for how much power you were putting through it
my vote is 9" ---parts are cheaper and more common and you have more headroom if you wanna get silly with the boost
Old 02-26-2017, 10:44 AM
rt338b's Avatar
what company brake is it as I am getting a trans specialties
Old 02-26-2017, 10:46 AM
Game ova's Avatar
Tci. It's an ok brake, I just don't care for having to hold a transbrake button just to reverse.
Old 02-26-2017, 10:49 AM
Game ova's Avatar
Yea, clutch had a few miles on it too. Yea I can dig that about the 9 inch, not really sure what I'm going to do just yet. Right now, I'm in paydown mode lol.
Old 02-26-2017, 11:40 AM
Nathaninwa's Avatar
What shifter do you have? You can wire the trans brake into the reverse light switch and get reverse, but I would use a toggle or something to shut it off at the track so if you go into neutral on the big end you don't accidently get reverse
My vote is a 35 spline 9 inch!
Quick Reply: Th400 First drive impression.
