95 lbs of fuel pressure
ok fuel pump hat with 8an feed 6 an return brand new for fox mustang tank. corvette filter plumbed properly....pump primes to 85/90..fire up motor it bounces from 80-95 while at 1600rpms occasionally going down to 75..as soon as the pressure goes down the motor clears up and sounds much better!....sooo...i'm guessing that either i have a return restriction or the filter is bad(brand new)...i even thought i had the filter plumbed wrong..so i swapped the lines ..that wasnt it...so i know its plumbed correct..today i will make up a 6an line to run into a gas can and trigger the pump and check the psi....so if its still crazy psi..i assume it would be the filter? thanks for any input.
It's odd, I've never had problems with them but I only buy the WIX versions. Seems lately people are having trouble with them regulating properly.
Personally I'm switching to another method on my next build and probably going to an external regulator. In my humble opinion it's a bad idea to build your fuel system around a part that was produced for one specialty vehicle (Corvette) and only used for a three model year year span (2000 to 2002) on said specialty vehicle. If that isn't bad enough, the price has doubled since I started using them and each time I want a new one it's not in stock.
yeah I def bought a cheap *** speedway one at first, but a wix did the same thing. I think a combination of things made it not run at 4 bar. bigger pump, different diameter and length feed and return lines. basically an entirely different system than what it was designed for, lol.
thanks guys for the input...now i just need to decide if i want to gamble on another filter or completely redo my fuel lines! argh!!!!...if i had this dam thing running and driving it would be an easier descision...its only run a few times-which is some hope lol!
soooo gathering info for a regulator...not sure if i have room to mount one on the fuel rails?..i guess a fender mount type? but then i have to run a return line alllllll the way back to the tank! dam!!!
Andrew! your the bomb!!..thats why i love this forum!!..i think that will be the ticket!..not cheap but its easier to change line ends than it will be to do a major reconstruction!! thanks again!
Andrew
I guess I’m still not seeing why you couldn’t you put any regulator in the same place and use the same plumbing? I have a standard regulator in the rear just like that and it’s dead headed to the OEM rails up front.
I’m all for neat and easy, sometimes it’s worth the extra cash. (not trash talking Holley or anything). Just don’t see the cost VS ease of install on that sucker VS any typical adjustable FPR on the market.
I do some, others, not so much. The particular regulator in question also has the filter built in. I am not saying it's better or worse than a regular regulator. The OP was having issues with the Corvette regulator and I remembered that Holley just came out with this.
Geez...tough crowd. Lol
Andrew
Andrew
I also like holley stuff, yes I guess I could have used a different regulator. i'm not really a fan of being under the car to set it. the holley fits what i'm doing just fine.i wont have to lengthen/replace my current lines and drop the tank yet again. i'm trying to get from under the dam car and in the seat! thanks for your input
ok heres an update...not a good one..installed the holley regulator....42 psi max at the rail..holley told me it was the pump that was bad..foolishly i went with that..replaced the pump with a aeromotive 340 (had a 340 already in it cant remember the name it came with the hat)..still 42 psi with holley reg...if i slightly restrict the return line i get 70 psi..this is with tank down so lines are nice and clear..............so i post on the holley forum and i'm told this regulator is only for 250lph or below?? not for such a big pump?? so i ask why a stock type regulator/filter would have an an8 ports? i would assume its for hp use?? well i assume wrong..so i called holley tech line today..get thru and the fella tells me he's never heard of this problem ever before and it should regulate any pump at a constant 58 psi..no problem...i can not make this stuff up...well i will be sending this holley thing back!! and going with what Forcefed advised a cheaper less expensive alternative..thats adjustable..i humbly say you were right!! and i ask what regulator you used in your setup..i will also have to add filter too...i will certainly tell anyone that will listen the holley filter/regulator is for a stock only setup...i equate it to the corvette regulator..it might work for some but not all....thats my story and i'm stickin to it
Sorry to hear it didn't work out...
I’ve used this Mallory unit on 4 builds now and not had any issues. That’s with E85 and a 4303 pump. The one on my rx7 has been going for 6 years or so now.
https://www.summitracing.com/parts/msd-29389
It's unfortunate to hear about your experience. I was actually thinking about getting one of those to replace the Corvette unit that I'm using, just for the sake of cleaning up my plumbing a little bit...
Andrew
Andrew
Very unusual for it to be so far out...are you sure the pressure gauge you are using is correct ?
Are you testing with the engine/pump actually running ?
No leaks prior to the regulator ?
i did verify the pressure with a mech. gage i had laying around..no leaks..i tested with mech gage just pump on..i have a holley hp so my sender is on the rail..and its 42 with the car running or just pump on. i believe i have ruled out the pump! lol..
hey forcefed..i had thought you were saying your fpr was less expensive? its more than the holley plus now i have to add a filter in this mix!...the cash is just flying outta my rear!!
on the holley reg/filter i wouldnt use one after taking it apart...the poppet thing for regulating looks even less impressive in person. if you have a stock type setup it would prob be just fine? i wouldnt chance it for anything above stock imho..i can tell you it spooks me from using their other adjustable fpr...
so a question i have is if i get a fpr that has a range only up to 65-70 max..this would be a bad idea even tho i only need 58? i would think the 95 pump max would maybe damage the fpr? i'm thinking the range should cover the pump max? yes?
thanks everyone!!
thanks everyone!!
Running a pump with no regulator and against a dead end is more likely to harm the pump than anything else.
If you have adequate fuel flow and no leaks prior to the regulator....then you can only assume that regulator is faulty
Which does seem very odd given its design and it being non adjustable. Unless somehow it is leaking internally.
And rather than hypothetical questions...state what regulator you are thinking of using. But why would a regulator that claims a range within what you want be an issue ?
