Cracked rod journal/ Callies compstar crankshaft.. cause?
Got a NA 402ci lq4. Tore it down for new bearings and rings as it has roughly 400 passes on it(bracket car). No symptoms, simply preventive maintenance.
7/8 rod journal is clearly cracked, I cannot imagine that it would have lasted too many more passes.
Looks like i got very lucky, could have been far worse. All rod bearings were in excellent shape except for number 7. Mains are in worse shape.
Question is, what would cause this? do I have a block/main alignment issue? Never blew a trans or rear end, never got hot, all motor. shift at 6800. Assembled short block was built by a reputable shop/sponsor. Was a new unused lq4 block when built.
thoughts?
4.005 bore
4" stroke Callies 4340
callies 6.125 compstar rods h beams
wiseco pistons
11.5 cr
th400 w/transbrake
thoughts?
4.005 bore
wiseco pistons
11.5 cr
th400 w/transbrake
It could have been a crack that was undiscovered when the motor was built. Did they Magnaflux the crankshaft before installing it? Did you contact Callies??? If not I would.
Rod is fine, No signs or of heat or any damage luckily. One half of the bearing was down to the brass. Number 8 bearing was mint.
The block is on its way to the machine shop for a line hone to be sure.
When the upper shell is copper but the lower is fine, usually points to detonation trying to back the crank up. Aftermarket forged cranks are harder/denser than cast but less malleable. A hardening flaw or lack of proper depth combined with higher order balance harmonics (think tuning fork) can cause it as well
I called Callies, they said they would look at it if i shipped it to them but they have no way of surmising if its a defect. So, basically **** up a rope they said. Im in Canada, im not shipping cranks all over the continent for no reason.
Called the engine builder(LME), I was looking for clarification on the crank part number. Build sheet says it is a 2.0 rod journal and the crank is clearly a 2.100.
He said he'd call back, haven't heard a word. Plus the balance sheet was never filled out. Some balanced and blueprinted short block I got here.
The local race engine builder will be getting all my work from now on.
it is a Powerbond keyed balancer.
