General ET/HP Database-What's your 1/4 mile time?
Old Oct 7, 2005 | 03:22 PM
777's Avatar
777
Default General ET/HP Database-What's your 1/4 mile time?
Table of Contents
          Old Oct 7, 2005 | 03:38 PM
          777's Avatar
          777
          OEM HP Ratings
          The ls1 is underated from the factory. This is proof of just that. Also note there is no significant difference in power between an ls1 corvette and any other ls1 powered vehicle. GM did this for marketing purposes.
          All times are driver specific, such as if you can't drive you won't be pulling these times.
          The corvette differs from the F-body in a few things. It is lighter, weighing in near 3200lbs (empty) [zo6 is around 3100lbs (empty)] vs. the F-body's 3600lbs (empty). It handles better, due to less weight, lower center of gravity, and better suspension (IRS). IRS makes launching a Corvette more difficult that is why they pull similar times at the strip. In a roll race or a top-end race the corvette *should* win, given equal drivers. Basically if you are buying one of these cars solely on performance to price ratio, there is no question an F-body is for you. Find the least optioned F-body (cheaper and lighter) and go to town. If pleasure and the factor are for you get a Corvette if you can afford it. Some people prefer F-body's over Corvette's in looks so basically get what you want for your specific purpose.
          Don't let someone persaude you into getting something you don't really want; because they aren't going to be spending the money for it, nor are they going to be driving it!
          Old Oct 7, 2005 | 04:01 PM
          777's Avatar
          777
          General
          Let me start off by saying that different combo's will have different power outputs when paired correctly. You can't just add A(15rwhp) and B(20rwhp) together and get C (35rwhp). This is especially important when buying cylinder heads and a cam. These two things are very important to do a lot of research.
          To make things easier here you go:
          Pay special attention to the posts made by Jrod if you aren't into reading a whole lot.
                  All Intake/Exhaust mods can be viewed Here as well as a description of each one and what you should look for when choosing one.
                  Old Oct 8, 2005 | 09:23 AM
                  777's Avatar
                  777
                  Intake
                  Free mods - 0-5rwhp
                  Lid - 5-10rwhp
                  Install
                  Big article on lids and dyno comparisions here
                  Filter - 0-5rwhp
                  MAF -
                  Very controversial as to any real gains, may even show negative numbers due to the fact it will be tricking the computer to run lean due to the larger diameter of the housing (good for stock, since you will gain a few hp by running a little leaner than the factory slightly rich setting; however, bad for modified vehicles). Stock MAF's are good to 500+hp. Once you are beyond that I suggest you contact your tuner (or local speed shop if you are doing your own) to find out what they recomend. Some will suggest taking the maf out and doing a speed density tune, which relies solely on the front O2 sensors.
                  Lid, MAF, Filter Install
                  LS6 (ZO6) Intake Manifold - 10-15rwhp
                  Install Graph
                  Holley Intake Manifold - 15-20rwhp
                  FAST 78mm Intake Manifold - 15-20rwhp
                  FAST 90mm Intake Manifold - 20-25rwhp
                  Sheet Metal Intake Manifold - 25+rwhp
                  Mainly for all out race engines or bigger CI engines.
                  Testing of Intake Manifolds Here
                  Also note that these hp figures can vary greatly due to cam size and head flow.
                  Ported Stock Throttle Body 5-10rwhp
                  Install
                  Cold Air Induction (CAI) - 5-10rwhp
                  Nitrous - Typically the size of the jetting will be the horsepower increase. Some company's rate it in flywheel and some to the rear wheels.
                  Exhaust
                  Listen
                  Cat-back - 10-15rwhp
                  Duals - 15-20rwhp
                  Catted y-pipe 5-10rwhp
                  ORY y-pipe 5-10rwhp
                  Shorty Headers 5-10rwhp
                  Mid-Length Headers 10-15rwhp
                  Long Tube Headers 15-20rwhp
                  Misc.
                  Underdrive Pulley 5-10rwhp
                  Tune 10-20rwhp
                  Electric Water Pump 5-15rwhp
                  Please DO NOT take the maximum number for everything and add it together and think you will gain this by adding these mods.
                  Your average full bolt-on (Intake/Exhaust) Should net you around a 50-70rwhp gain, depending on how well your car responds to the mods that you do. I believe the highest bolt-on dyno is upwards of 380rwhp 390ft/lbs.
                  Stock dyno's range from 290rwhp-315rwhp. Automatics will dyno considerably less than a manual. Also such things as lightened flywheel will free up some hp as well. A bigger rear-end such as a 12-bolt or a 9" will show negative gains on the dyno. But you won't be breaking anything and you will run a faster e/t due to the better launch you can have.
                  Old Oct 11, 2005 | 03:25 PM
                  777's Avatar
                  777
                  What will I run?
                  1/4 mile Calculator
                  Enter in weight (3600lbs stock) and enter hp number. It takes flywheel hp to be accurate so adjust manuals by rwhp * 1.15 = ~flywheel hp. For automatics - rwhp * 1.20 = ~flywheel hp.
                  To be even more accurate look at this database and find the times closest to yours. Then look at the modifications they have by clicking on the model of the vehicle (blue). Keep looking around until you find a car with similar mods. Then you can have a fairly good guess. Do not just go and find the fastest time that has your mods. Make sure to take in consideration the weight (reduced) and the tires (drag radials/slicks). These can drastically affect the way the e/t will be. Just try to be honest with yourself and you should have a good idea of what you should run at the track.
                  If you want to know for sure take it to the track!
                  Old Oct 12, 2005 | 10:17 AM
                  777's Avatar
                  777
                  A section for cams and possibly heads may come along later, I figured I'd get this up ASAP. If you have any information to add, notice errors and/or incorrect info, links dont work, or you think this is of no use to the site PM me. Thanks.
                  LS1Tech Staff Member,
                  Kevin
