Racetronix Fuel Pump Kit LS1: BRAND NEW!!
This is a BRAND NEW KIT! I never even opened the box it came in! Plans have changed and I need more fuel. My loss is your gain.
Copied from Harris Speed Website:
Kit comes compleate with Fuel Pump Kit & Wiring Harness.
For use with '99+ LS1 (Plastic Tank Cars) Camaro / Firebird / GTA
Fuel Pump Kit:
-Plastic tank cars only
-Custom Racetronix / Walbro pump
-270L/Hr @ 43.5PSI / 235L/Hr @ 58PSI
-Venturi feed system - Racetronix exclusive
-Red anodized billet aluminum pump assembly
-Racetronix to GM Teflon wiring harness
-High-pressure non-kinking G.M. fuel tube
-Custom 30 micron filter sock
Wiring Harness:
-Plug & Play (no soldering or crimping required)
-Waterproof Delphi Weatherpack connectors
-Heavy 10 Gauge stranded copper wire
-Siemens / P&B 40A Mil. Spec. waterproof relay
-Waterproof Delphi fuse holder w/SS hardware
-Direct alternator hookup for maximum voltage
-All connections crimped AND soldered
-Silicon grease, spare fuse, wire ties included
-8Ga. body ground upgrade w/ brass battery nuts
* PnP compatible w/ MSD or KB Pump Booster *
$235.00 shipped. Save $50.00 on something that is BRAND NEW!
Fuel Pump Kit:
Wiring Harness:
