Pushrods for sale...
7.450" for my F13 with non-milled heads. If you are running an F13 cam or a cam with a similar base circle (1.450") and stock or unmilled heads, these are the pushrods you will need to get the PROPER preload on your lifters and beable to get the most power out of your setup. They give me a 0.080" preload with AFR heads and GM MLS gaskets.
They have 1000 miles on them and I am only getting rid of them because I am milling my heads and need 7.425" PR's so I dont have too much preload. They are on the car right now but I will take them off once I get payment.
The are comp cams CM pushrods
$75 shipped, if you pay with paypal add $3 for fees.
Stock length is 7.400", I have no idea if itwill work with your cam, it is all based on what lifters you have, base circle and heads. They are made by comp cams.
