LS6 rotating assembly
Old Aug 13, 2006 | 10:39 AM
slowride's Avatar
Default LS6 rotating assembly
Crank is in perfect condition and ready to drop in. The old main bearings which are in good shape that come with it and it ships in a Eagle box so it is safe. Crank had 37k on it. $160 shipped.
7 good(1 bad) ls6 pistons (fly cut -1cc on the intake) and eight rods for sale from the above crank. Only need a new/used ls6 piston and some rings and it's ready to go. Bearings are included with the rods and they look excellent. Perfect upgrade for someone using a stock bore or a small truck block bored out as this rotating assembly is balanced from the factory. $70 shipped
Sell both for $210 shipped.
Old Aug 13, 2006 | 11:10 AM
gEtyOPaPiOn's Avatar
what happened to the 8th piston ?
Old Aug 13, 2006 | 01:38 PM
slowride's Avatar
Typical #7 leaned out on a heads cam engine and broke the ring lands. Was running stock 28.8 injectors at 445whp and something just wasn't running right. I've moved on to 30lb SVO injectors so all should be well after the tune.
I almost reused all of this, but got bit by the stroker bug. It's all in perfect shape except for the one piston. All the pistons are fly cut on the intake -1cc
Old Aug 14, 2006 | 12:08 AM
slowride's Avatar
Price lowered
Old Aug 14, 2006 | 11:12 PM
slowride's Avatar
Rods sold, pistons and crank still available. Just had the crank polished tonight
Ed
Old Aug 15, 2006 | 12:00 AM
slowride's Avatar
Edit. Crank sold. 7 pistons to go
