Lots of stuff for sale... including C5R block 427
Old Aug 31, 2006 | 03:34 PM
BurnOut's Avatar
Default Lots of stuff for sale... including C5R block 427
Lots of stuff has to go...
- 427 LSx long block; C5R block w/ Lunati rotating assembly, ported LS6 heads, copper head gaskets, O-rings, etc... 10.8:1 compression, built with nitrous in mind. Cam is something like 230/236, .600-ish on the lift, 115 LSA. Motor supposedly made just shy of 590 at the crank when it was tested at Doug Rippie Motorsports (that's who also built it). Bought used, been sitting in a crate ever since... $11k
- Jesel Mohawk LS1 rockers; 1.7 ratio. Bought new, ran them on my car for less than 1000 miles... $750 SOLD
- Schubeck LS1 lifters; same story as Jesel rockers... $150
- Comp hardened pushrods; 7.25" (I think; will verify), same use as lifters and rockers... $50
- ATI damper for LS1 F-body; also have Katech "solid" belt tensioner and all belts... same usage as lifters and rockers... $350 SOLD
- Ram dual disc clutch w/ aluminum flywheel for LS1; can't remember the part number, but it's new and comes with an adjustable master cylinder for an F-body... $750 SOLD
- 1" valve cover spacers for LS1; come with all hardware/gaskets... $175
- LG Motorsports airbox lid for LS1 F-body... $50 SOLD
- Cola 4" crank for LS1; 4340 steel, .125 fillets on rod journals, comes with new LS1 reluctor wheel... bought new, never used... $1100
- SB2.2 "Nascar" heads; came out of Hendrick Motorsports shop (CNC ported, etc...), includes complete heads (titanium valves, etc...), offset 1.75 Jesel rockers (to allow heads to be used on regular SBC block) and stands, magnesium valve covers w/ gaskets... $2500
- Vortec 350 ('96-'98 GM trucks) long block; ~50k miles, just needs valve covers, intake, and distributor to be a runner... $550
- 4WD TH400 w/ NP208 transfer case; worked when removed from truck, probably needs rebuild, stock converter included... $250 SOLD
- Brembo brakes for 4th gen F-body; 4 piston calipers, 13" rotors... bought used, never installed. Some light cracks on rotors, had them checked at LG Motorsports and was told that they're okay... also have LS1 spindles to enable brakes to go onto LT1 cars... $1500
- 4" SpinTech muffler; used for about 2 weeks... $50
All parts are in the Dallas metroplex area... will deliver heavy parts (motor, transmission) within 50 miles for free, all other shipping to be paid by buyer. Big prices are negotiable to a point.
PLEASE SEND PM IF INTERESTED IN PARTS, AS I DO NOT REGULARLY CHECK THIS THREAD
Old Aug 31, 2006 | 03:55 PM
sr71bbjr's Avatar
would you sell me juust the short block?
Old Aug 31, 2006 | 04:09 PM
BurnOut's Avatar
You have a PM
Old Aug 31, 2006 | 06:14 PM
BurnOut's Avatar
ttt for me
Old Aug 31, 2006 | 07:07 PM
will350wax's Avatar
How does the lid look? (cracks or chips)
Old Sep 1, 2006 | 08:39 AM
BurnOut's Avatar
Lid is perfect, has IAT sensor in it.
Old Sep 1, 2006 | 02:41 PM
will350wax's Avatar
pm sent
Old Sep 7, 2006 | 10:14 AM
SOULPOWER's Avatar
still have the lid??
Old Sep 13, 2006 | 06:04 PM
ROCNDAV's Avatar
still have the pushrods?
Old Sep 13, 2006 | 07:16 PM
SILVER SS 00's Avatar
do yuo have pics of the twin disck send to nunoacosta@yahoo.com
Old Sep 17, 2006 | 07:32 PM
JBM's Avatar
JBM
Default rockers
Are the Jesel's still available?
Old Sep 17, 2006 | 08:53 PM
01m6ss's Avatar
do you still have the vortec 350?
Old Sep 26, 2006 | 11:27 AM
ROCNDAV's Avatar
Do you still have the pushrods, and were you able to verify that they are indeed 7.250?
Old Sep 26, 2006 | 12:53 PM
mbraun's Avatar
do you have the adapter brackets for the brembo's? Please email pics to mbraun@kc.rr.com thanks
Old Oct 15, 2006 | 03:52 PM
SLED28's Avatar
Do you still have these?
Old Nov 6, 2006 | 03:25 PM
Hardtop94's Avatar
still have the lifters? will they work on a stock ls1? well for use when i do my head and cam swap?
Old Mar 2, 2007 | 08:47 PM
streetassasin's Avatar
If he gets the short block I want the heads Im talking about the vortec 350
Old Mar 2, 2007 | 09:10 PM
02ZOh6's Avatar
If the clutch is part #35-90-2100 Thunder Racing
I'll take it. PM me please.
Old Mar 3, 2007 | 01:04 PM
02ZOh6's Avatar
Who dug this thread up? It's way old. I'll still take the clutch if you have it though.
