Pontiac GTO 2004-2006 The Modern Goat
stock 1/4 times in ur gto
Old Nov 23, 2006 | 01:25 AM
erskine's Avatar
Default stock 1/4 times in ur gto
maining looken for the stock 05-06 gto, looken to pick one up next spring.
Old Nov 23, 2006 | 02:49 AM
KrautBurner's Avatar
stock, and new
first time at the track, 13.8
a month later 13.5
now I have borla cat back and K&N 13.002@106
shooting for high 11's in spring
Old Nov 23, 2006 | 03:32 AM
8100hammer's Avatar
12.94 at 108mph stock 45* weather.
12.60 at 111mph with WMP tune,street tires, and a few minor susp bits
Old Nov 23, 2006 | 11:09 AM
oct03gto's Avatar
You can see better times out of the A4's. I have an 04'. With a stock tune, 245 tires, LT's, and catback. I got a 13.008 @ 107.89. If I could keep traction in 1st gear. I know I could have had 12 high 12's. Not bad for a full exhaust and a six speed car.
Got 3.91's, cam and FAST 78mm intake with a tune comming in the spring. I am hoping for mid to low 12's. Might need a clutch by then too.
Old Nov 23, 2006 | 02:37 PM
erskine's Avatar
sweet guys thanks
Old Nov 23, 2006 | 09:12 PM
LITE SPD's Avatar
I ran 15.1 at 100mph my first time out in the GTO. I brought it down to about 13.7 with minor bolt ons. I'm at 12.77 at 112.95 with a 2.1 60ft with a very mild head cam setup. 2004 M6.
Old Nov 24, 2006 | 12:58 AM
sweetness's Avatar
13.7 first time at the track (a4) i spun really bad stock tires and 35 degree weather will tend to do that
Old Nov 24, 2006 | 01:34 AM
floman's Avatar
2005 6spd bone stock BFG factory tires 75 deg weather- 13.447@104.56 w/2.018 60 ft
Bone stock with 245-45-17 Nitto Drag Radials- 13.244@103.84 w/1.952 60 ft
These times were made lift shifting with 3/8 tank gas, race weight of 4060 lbs with no weight reduction, obviously.
Old Nov 24, 2006 | 11:56 AM
al rocha's Avatar
I ran 13.48 at 104.
Stock tire pressure to the stock air filter.
AL
Old Nov 24, 2006 | 11:59 AM
Greeny5005's Avatar
12.2 at 117 2.0 60ft not that i apply
Old Nov 26, 2006 | 12:56 AM
NovaTodd's Avatar
Look at my sig.......Car is still bone stock - the heat is a killer on these things
Old Nov 26, 2006 | 04:17 AM
most 05's are running upper 13's and low 14's stock (in my area)
06's are running mid to upper 13's
Old Nov 26, 2006 | 07:14 AM
silverls2gto05's Avatar
i have an 05 A4 and i ran an 13.6 in 90 degree weather
Old Nov 27, 2006 | 03:16 PM
erskine's Avatar
is that without a driver?
Old Nov 27, 2006 | 05:26 PM
oct03gto's Avatar
Mine weighed in at 3890 LBs with 1/3 tank gas 165 lb driver, and missing spare tire and jack.
Old Nov 28, 2006 | 02:07 PM
erskine's Avatar
ok that sounds better, dam these are some heavy weights
Old Nov 28, 2006 | 06:19 PM
oct03gto's Avatar
Yeah, they are a bit heavy. But, I got a 13 flat with almost 4k lbs, and only 335 HP at the wheels. That is not bad. Plus, I am a horrible 1/4 mile driver. Only been down the track a handfull of times, and still need to dial in both myself and the syspension.
I know high 12's could be had with my car before the gears and cam go in. I amlooking for mid to lower mid 12's after those.
Old Nov 28, 2006 | 09:44 PM
big r's Avatar
I ran 12.7 @109 at Atco last May in 65 deg weather. Then backed it up several times with a 12.8 with the same mph. There are two important mods with these cars. 1. DRIVER. 2. DRAG TIRES. With these two mods our cars will go 12s very easy. I practice my launch constantly, because my car gets tempermental with weather changes.
Old Nov 28, 2006 | 09:51 PM
Speedy0009's Avatar
I have an '04 M6. With 3.91 gears, drag bags, rear sway bar, crossmember bushings I ran 13.68 @ 103. With Kooks LT headers with catted mid-pipes and a tune I was running the same times, all with the fastest of 2.03 60'.
Upcoming spring will be much different but those were my "power-mod-less" times and they were the same with the headers . . . so I have an average '04. Race weight two times at the track were 3890 and 3880lbs both times with me in the car (180-185lbs), full street trim (spare, jack, tools etc.) and about 1/4 tank of fuel....!
Spring 2007 where are you so I can run with my ProCharger and DRs??
Old Nov 28, 2006 | 10:10 PM
Caveman's Avatar
10 & 11 Second Club
The best I ran stock with the GTO was 13.53 @ 104 last summer in nighttime 85* weather.
