More Valve Spring Comp. Tool
I have a more valve spring comp. tool i have never used. More Performance's valve spring compression tool works on C5, F Bodies and all LS1 powered vehicles. The main body is made of billet aluminum and incorporates a steel roller bearing trunion for ease of operation. This tool is designed to work with any 3/8 hand ratchet, simply add a 3/8 extension for valve springs which are difficult to reach (under cowl). Will work on factory conical valve spring along with aftermarket 1.25" OD spring/retainer sets. This thing new was $129.00 I will let it go for $80.00 shipped, I have paypal.
Also, I have a AMS LS1 steel Flywheel 23lbs-3lbs lighter than stock SFI rated
was on my car with a centerforce clutch for 5,000 miles and then i went with a LS7 clutch package and no longer need this. Other than needing cleaned up its ready to bolt on. $55 shipped
