LG Motorsports on the Dyno! L92 Heads/cam!! Numbers with in!
Old Feb 1, 2007 | 07:38 PM
Louis's Avatar
Default LG Motorsports on the Dyno! L92 Heads/cam!! Numbers with in!
Hi guys!
Stock LS2 shortblock, mildly touched up L92s, Untouched L76, G6x92-3 L92 specific cam kit and the LG Pro Longtube headers for an astounding 484/455 SAE rwhp on a dynojet!
We are up late tuning and working on these packages for you guys, so stay tuned! I will upload the graphs later on tonight or tomorrow morning.
Louis
Old Feb 1, 2007 | 07:48 PM
Dragaholic's Avatar
9 Second Club NA
Could you go into detail on mildly touched up?
Valves? Metal? Weight?
Springs, retainers, etc.?
Would you consider the cam mild or wild?
Flow numbers on the heads?
6 speed or automatic?
Old Feb 1, 2007 | 08:06 PM
Stang's Bane's Avatar
Louis, have you considered putting in one of your G7x series cams with these heads?
Old Feb 1, 2007 | 08:34 PM
WizeAss's Avatar
Originally Posted by Louis
Hi guys!
Stock LS2 shortblock, mildly touched up L92s, Untouched L76, G5x3 L92 cam kit and the LG Pro Longtube headers for an astounding 484/455 SAE rwhp on a dynojet!
Louis
glad you got those rockers!!! sorry we couldnt help.... based on those numbers you would figure my 408/ported L92/L76/Beast Cam setup would be good for over 530rwhp and 500 torque.
Nice numbers!!! I wanna see those curves.
Old Feb 1, 2007 | 08:51 PM
Louis's Avatar
This is actually a similar version of the G7x3, it is not the G5x3, sorry for that. Its a variation of the LS7 stuff and what we have learned from it. Lou named it the G6x92-3
Old Feb 1, 2007 | 08:57 PM
what compression l92 vs afr's ?
Old Feb 1, 2007 | 09:54 PM
Cop Car's Avatar
guessing this is on a C6 M6?
Old Feb 1, 2007 | 10:16 PM
Louis's Avatar
car in the sig
CR was the same, 11:1
Old Feb 1, 2007 | 10:24 PM
Dragaholic's Avatar
9 Second Club NA
How about some answers for me that I posted above?
Old Feb 1, 2007 | 11:38 PM
JakeFusion's Avatar
Super Hulk Smash
car in the sig
So you switched from the AFR 205s to the L92s?
Old Feb 2, 2007 | 01:59 AM
Louis's Avatar
Dragaholic, cam is mild, IMO.
Car is a 6 speed.
Head setup is undisclosed at this point until we know more for public consumption.
Jake- It had AFRs, and also had ETP 4" bore LS7s as well.
Old Feb 2, 2007 | 02:03 AM
Louis's Avatar
tomorrow, we will bump the limiter to 7200~ and see where we stand.
Old Feb 2, 2007 | 06:56 AM
11 Bravo's Avatar
Damn, nice torque curve. Looks like a 402.
Old Feb 2, 2007 | 07:42 AM
First time I looked, I was not that impressed, then I remembered it was a 364 not a 40x. Very,very impressive!!
Old Feb 2, 2007 | 08:19 AM
Patrick G's Avatar
LS1 Tech Administrator
So let me get this straight...
You had AFR 205s with FAST intake and made 495/470.
You swap to L92 heads, L76 intake, appropriate cam and make 484/455? Comparable compression and same exhaust?
First off, let me commend LG for always staying out front in the R&D department. I'm happy you did this experiment, but to me, it raises as many questions as it answers. I know the L92 stuff is quite a bit less expensive than the aftermarket heads/intake, but what does this exercise prove? Lower power for less money?
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Old Feb 2, 2007 | 08:36 AM
ScottyRocket's Avatar
Higher flowing heads.... you need more cubes or more RPM period!
That's why they are going to bump up the RPM limiter.
This is a small engine already.... 364 cu in.
Edit: This is given the same cam. But once you hit the wall with more cam, you'll need what i mentioned to get more power.
Old Feb 2, 2007 | 08:44 AM
tmoneyr007's Avatar
I'd like to see an overlay of the AFR/Fast/G5X3 and the L92 setup, it'd be interesting to see what the torque is doing on the low end....
Old Feb 2, 2007 | 09:17 AM
beardWS6's Avatar
MORE CUBES needed for these heads, this is from a couple builders that I talk to! Good info, Thanks!
Old Feb 2, 2007 | 09:31 AM
Ratical's Avatar
From the graph, it looks like the power already peaked out around 6500rpm. Did you actually start the run at 3500rpm, or is there a dip in the curves at that rpm?
Nice numbers for a 364ci motor.
Old Feb 2, 2007 | 09:41 AM
ringram's Avatar
I think you will want a bigger cam if you raise the RPM limit as it looks all over already.
Or as mentioned more cubes.
Still for the guys with a Holden VE with the L92 heads and the new Pontiac G8 on the way, cam only guys will be having a great time!
