New info on Mickey Thompson's new drag radial
Old 02-22-2007, 09:07 PM
ls1muscle's Avatar
Default New info on Mickey Thompson's new drag radial
Everyone is wanting to know about these tires and when they're coming out. I noticed awhile back a member on supraforums was lucky enough to be able to get his hands on the new design/tread in a 315-35-17. I sent him a PM and asked a few questions about how the tires were, as I wanted some real world results about these new tires.
And this was his response:
"The tires are awsome in the dry, definately better than bfg drag radials hands down. They do not spin @500whp in 1st 2nd or 3rd gear (cold). Unlike the bfg's that need a good burnout to really hook. I havent taken them to the track yet as I put them on in december I think. I will know here next month how they work out at the track. They are not good in wet weather at all, I almost lost control a few times around a corner at 20mph. The bfg's definately work better in the rain. I wouldnt recomend them to anyone who drives with allot of rain. But the dry traction is awsome and worth it. As of now I have around 9-10k miles on them and they are still about 75% left. I think they come with 8/32nds tread new. They do have a bit of sway on them unlike the bfgs (even at 40psi) this is probably because they have a very soft sidewall for a radial, I mean really soft, somewhat like a bias ply drag tire. Which should work for us guys with the 6speed as it should keep down the driveshaft breakage."
"Just took lunch and was merging onto the freeway in 2nd gear, flored it and spun all througn 2nd to wear the tires in a bit. Got off the exit and went in 1st gear like normal and then floored it around 4k till around 8k, shifted to 2nd and they hooked like grazy with zero wheel spin!!. I usually light up my 315 R compound Advan's. And this was with the weather around 55 degrese outside. I had bfg dr (2754017) before and they didnt hook to save their life when it was cold."
I know everyone has seen these pictures
And here's actual pictures of them on the car
Old 02-22-2007, 09:21 PM
TRU-2GM's Avatar
Thats awesome that they are performing well, and they look mean as hell too!
Old 02-22-2007, 09:22 PM
Kleeborp the Moderator™
MeentSS02's Avatar
Hmmmmmmm...looks like there will finally be something that will hook worth a damn in an 18" diameter...I love the tread design too.
Old 02-23-2007, 03:52 PM
Lythropus's Avatar
They don't spin in first gear with 500 horsepower when they're cold? What are they wrinkle wall???? Or did I just read that wrong?
Old 02-23-2007, 05:23 PM
24v
24v's Avatar
"They do not spin @500whp in 1st 2nd or 3rd gear (cold).........................As of now I have around 9-10k miles on them and they are still about 75% left."
Does not compute.
Old 02-23-2007, 06:30 PM
ls1muscle's Avatar
I find this hard to believe as well, but hey, just passing along info from someone who was able to get them before anybody else.
Old 02-23-2007, 06:52 PM
BMW ///M Nerd
BAD ASS TA WS6's Avatar
305/35/18! The tire sizes listed are amazing. They really took this tire to a new level....
That's exciting, but getting 9k out of them is rediculous. He obviously lays into the throttle often, so the 9k life with 75% tread remaining is not right. Straight up...
I get 5k out of my 17" BFGs with maybe 5 track runs, and street driving/beating.
Old 02-23-2007, 07:07 PM
7 Second Club
Phil99vette's Avatar
Wonder what the advantage is, tire sizing? I need some 325/50/15.
Phil
Old 02-23-2007, 07:32 PM
NoGamesLS1's Avatar
Will the 295/45 17 fit on a stock ws6 rim?
Old 02-23-2007, 07:39 PM
Administrator
unit213's Avatar
I'm not 100% positive, but I would say yes. Nitto 315 drag radials
fit on a 9" wheel, but they are really like a 295. If the Nittos fit, I'm
assuming a 295/45/17 would fit as well.
Nice option for an 18" wheel. I'd like to upgrade to some 18" wheels
for a daily driver setup. These would be perfect.
Old 02-23-2007, 07:41 PM
GeArBaNgEr56's Avatar
Thats going to be badass, I'll have to pick up another pair of ZR1s.
Old 02-23-2007, 07:58 PM
BMW ///M Nerd
No, you're an 1" short on width. Factory WS6 wheels are 17x9s.
People run 315 Nittos on factory WS6 wheels because they run narrow. It's still wrong, and people have still had blowouts/failures. LOL then they wonder why...
The sidewall on the 295/45/17 is also almost a full inch taller than the factory 275/40/17. So it's going to buldge pretty bad. That, combined with the really soft sidewall.... The tire separating/tearing off of the bead is definately possible.
Old 02-23-2007, 08:02 PM
Administrator
unit213's Avatar
Bah...thousands of Cobra guys, including myself, run 'em on stock 17x9's
and I've not heard of a single issue. I've run through three pair so far.
Good point on the tire height.
Old 02-23-2007, 09:30 PM
BMW ///M Nerd
I know, I know. I've seen it done PLENTY of times myself. But there has also been proof of this type of failure with pictures right here on this board.
Old 02-23-2007, 09:34 PM
'Trust''s Avatar
on the 315/35/17 MT DR!!
Old 02-23-2007, 10:39 PM
MeentSS02's Avatar
That doesn't make it right though...tire manufacturers certainly won't back it, and for good reason. IMO, it isn't safe.
Old 02-23-2007, 10:59 PM
Administrator
unit213's Avatar
Originally Posted by MeentSS02
IMO, it isn't safe.
I disagree, but that's fine. No one is forcing anyone to run a tire
they don't want to.
They don't hook well enough for me anyway. 28" slicks to the rescue.
Old 02-23-2007, 11:53 PM
HAMRHEAD's Avatar
I'm liking these 315's for the street!
Old 02-24-2007, 12:33 AM
Racer
UL LOSE's Avatar
So does anybody know when exactly these tires will be available to purchase?
Old 02-24-2007, 01:30 AM
Stangkilr's Avatar
Thats what I want to know.
Quick Reply: New info on Mickey Thompson's new drag radial
