FS/Trade: Moser 12 bolt, 3.73, posi (NY)
Moser 12 bolt (4 channel ABS/TCS) out of a LS1 f-body. The rear is located in Rochester, NY and is currently in my car. I would be happy to take anyone for a ride to verify its condition and I can remove it from the car as soon as I have a buyer.
-4000 miles
-4 channel ABS/TCS
-33 spline axles
-3.73 gears
-aluminum rear cover
-1350 yoke
-Eaton 800lb posi
-painted black
-relocation brackets welded in
-upgraded carbon clutchs
-includes brake mounting brackets
The rear is in perfect used condition….no vibration, completely smooth at very high speeds. It has a slight whine, but nothing drastic at all. It has been to the track 1 time….and that was on 245 Nitto drag radials (1.9 60ft.). Was $2550 new.
I really do not want to ship this….so, I am only making it available to someone willing to pick it up (or I am willing to meet part way within reason).
Price: $1800 or $1550+ good stock 10 bolt rear (with brake mounting brackets) with 3.42, 3.73, or 4.10 gears.
I will also entertain trades (or partial trades) on the following items:
-AFR/TFS, or good ported heads
-17” wheels/tires
-90mm throttle body
-36 or 42# injectors
jhsformula@aol.com
Thanks!
-4000 miles
-4 channel ABS/TCS
-33 spline axles
-3.73 gears
-1350 yoke
-Eaton 800lb posi
-painted black
-17” wheels/tires
-90mm throttle body
jhsformula@aol.com
Thanks!
Thanks, selling it because I spend little to no time at the track.....I am just a "street" guy now. Plus, I would like to get a set of ported heads without having to spend any money "out of pocket".
Thanks!
Jason
Thanks!
Jason
Send some pictures to michaeljhowie@gmail.com if this is still for sale please. I am also located in Rochester, NY (Town of Greece near the intersection of Latta/Long Pond). Where exactly are you located. I could come check it out sometime if it's still for sale.
