93-02 Z28 PARTS...filler panel, fender, tail lights, headlight bar, etc LOTS OF PARTS
Random parts:
-Custom brake booster. Based in house of kolor black and then sprayed with red miniflake. 3 coats of clear on top of that. I was going to run it on my show car but ended up going with manual brakes. $50 obo. I have more then that in the paint on it.It does has some dust on it in the picture. It looks great when the sun hits it!
-Brake master cylinder and abs block w/ lines. pic below. Pictured set up is for a LT1. I also have a LS1 set up. make offer
-94 Z28 owners manual. make offer
-One off HVAC box modifed to only run heat and no ac. All AC parts and ac core were removed from the box to save weight. Box was cut and redesigned to give a better appearance in the engine bay and give you more room. I can take some pictures of it if you would like. Based in black and then it has a satin flat automotive clear over it to give it a chassis black look. make an offer.
-10 bolt Gears: 1 set of 3.23s and 2 sets of 2.73s. All in great condition with low miles. $30 for the 2.73s and $50obo for the 3.23s
-Hood latch cable. fits 93-02. $10
-A4 pedal set. Fits 93-02. make offer(pic below)
-98-02 Trans Am passenger headlight cover. Slight bend on the tip but easily fixable. make offer(pic below)
-93-97Trans am front turn signal blackouts. make offer
-93-02 trans am rear marker lights for bumper. make offer
-94 trans am owner manual. make offer
-93-97 LT1 valve springs, retainers, locks, and lifters. all have 35k miles on them. make offer on what you want.
-LT1 water pump cam drive splined shaft. make offer
-Key & lock combo's. Includes both door lock cylinders, rear hatch lock cylinder and matching key. make offer.
-93-02 Formula hatches. I have numerous colors. make offer and pm me if you need a certain color.
-93-02 camaro hatches. I have numerous colors. make offer and pm me if you need a certain color.
-93-02 Z28 manual crank window doors. Green in color. Includes doors,handles,locks, and all crank mechanisms inside. NO interior panels. $120 for the pair obo
I have the following parts available off a 96 Z28:
All prices are w/o shipping
-Headlight support bar with all the lights and adjustors(pic below). make offer.
-Tail lights (Will fit all 93-02s) $50 obo 1 set sold. 1 set left!
-Tail light wiring harness. make offer1 sold. i have 3 or 4 more
-Rear filler panel that says "CAMARO".(Fits 93-02) $40 obo
-Rear quarter panels in perfect condition.(Fits 93-02) make offer
-Pass and Driver doors in great shape. power windows. complete with everything but the interior panels.(Fits 93-02) $65 per door obo
-Driver side fender in great condition. make an offer
-A4 trans cross member $15(pic below)
-Gauge surround trim $25
-Fuse cover $10
-Front bumper orange light. $8 (pic below)
-Automatic console insert (pic below) $15
-Pair of Z28 exhaust tips. $15
-Grey complete seat belt set.Includes every seat belt and latch out of the car.(Fits 93-02) $65 obo
-Manual lock slide buttons. These are the pieces you slide to manually lock your doors. They normally get broken when removing the door panels. These are in great shape.(pic below) $5 for the pair
-Complete set of BOSE speakers. I have the door speakers, sail panel speakers, rear sub, and amp. Make an offer on what you need.(Fits 93-02)
-AC compressor. Great condition. make offer.
-EGR tube that runs from one header under the engine to the other header.See below pic. make offer
-Air bag panel for the dash. This is the panel out of the dash that covers the air bag. Great condition. $50 obo
-Stock LCAs, panhard, torque arm, spindles,brakes,upper and lower from a arms, k member, pwr steering rack. make an offer
-Stock front and rear brake rotors. make offer
-parking brake cables. $15 per pair
-parking brake handle and assembly $15
I have the following off of a 01 Z28:
-Air box lid. pic below. make offer
-Passenger side headlight.SOLD
-Optional OEM side ground effects. Come complete with all the mounting tabs that rivet to the body to hold the skirts on so you do not have to use two sided tape. Great condition.(Fits 93-02) make an offer.
-Optional OEM rear ground effect riveted to the bumper as it comes from the factory. Bumper and ground effect will be sold together since they are attached with rivets from the factory. Paint is in great condition.(Fits 93-02) make an offer.
-Stock muffler.(Fits 93-02) $25
-Front Core support.(Fits 93-02) I'll cut it off completely so you can drill out the spot welds whever you would like. $70
-Automatic shifter assembly $30
-Steering collumn w/o wheel. comes with key.(Fits 93-02) $30
-Stock torque converter. 20k miles on it. make offer
-Stock LCAs, panhard, torque arm, upper and lower from a arms, k member,pwr steering rack. make an offer
ALL 93-02s use the same exact door. There are no differences at all. Everything fits the same. I have a console lid off the 96 but it will not fit on the 97-02s. Yes I do have the sail panels. Shipping on them and the door would be best through grey hound if you want to save money. PM me and let me know if you have a grey hound local to you and I can get you a shipping price.
Yes I have pictures of them still. I can ship them but it will be high since the sideskirts and bumper/ground effects are very large. Shoot me a PM and i'll get you pictures.
Doors are still for sale. Everything is for sale till its marked sold and I may have multiples of some parts.
