plate to cover radio and hvac controls if removed
Old Dec 3, 2007 | 10:20 PM
SVC707's Avatar
Default plate to cover radio and hvac controls if removed
this plate is 3/32" thick, thick enough to hold guages/switches. cut to fit both the radio and hvac controls, if you only have one or the other you can cut it and save the rest for later if needed. all you have to do is use your choice of glue/epoxy to mount it as i have.
$15 shipped via paypal, plate only
or send me your bezel and ill mount it for $30 shipped back to you.
oh also have another one which is 1/32" if not planning on putting switches into it. $12
Old Dec 5, 2007 | 01:51 PM
SVC707's Avatar
t t t
pms replied
Old Dec 11, 2007 | 11:25 AM
SVC707's Avatar
I have the 3/32nd thick cut out for either radio or havc controls.
Old Dec 28, 2007 | 09:06 PM
SVC707's Avatar
ive got several of the thicker plates for radio only.... ttt
Old Feb 21, 2008 | 05:49 PM
SVC707's Avatar
i made more of these, so let me know what combination you need if just radio or hvac
thick/thin etc
Old Apr 9, 2008 | 04:10 PM
SVC707's Avatar
just want to share one on a camaro, i believe its grey in color but still matches pretty cleanly
Old Apr 18, 2008 | 10:56 PM
SVC707's Avatar
moving up
Old Apr 28, 2008 | 06:07 PM
SVC707's Avatar
T T T
Old May 5, 2008 | 11:08 AM
SVC707's Avatar
b u m p
Old May 5, 2008 | 12:06 PM
stangeater01's Avatar
good seller quick shipping thanks
Old May 5, 2008 | 06:00 PM
95GreenZ28's Avatar
What are the dimensions on the hvac cover? I have a 95 and I wanna make sure it will cover the whole area
Old May 6, 2008 | 09:29 PM
95GreenZ28's Avatar
Any dimensions
Old May 6, 2008 | 10:02 PM
SVC707's Avatar
my bad, sorry i could not find a ruler or measuring tape as i got alil busy with work. i made it off the actual bezel. but ill measure it up tomorrow as tomorrow looks pretty dead at work
Old May 7, 2008 | 07:35 PM
95GreenZ28's Avatar
ok sounds good man thanks
Old May 8, 2008 | 07:00 AM
95GreenZ28's Avatar
Im going to be using one on my 95 so I just want to make sure it will be wide enough
