4.8l truck motor-High revver?
3.27 stroke and 6.278 rods means a rod/stroke ratio of 1.92 which is VERY good. This is just a touch more than the 69 Z/28 302 (1.9 rod/stroke ratio). It should rev like crazy without too much stress on rotating assembly.
I'm just wondering with the stock rotating assembly, what kind of RPM's this motor could turn given the ideal cam and valve train.
Sure it's a small motor, but at the ripe price free, what do I have to lose.
With the 4.8L and a 2100lb. BMW, you can't tell me it won't be fun. Heads/cam/tune would put it right at 380/320 @ fly and still cheaper than getting a LS or 6.0. Sure a LS or 6.0 would make more power, but I didn't get either of those for free.
But yea I can get a 19k 4.8 for nearly half the cost of a similar condition 5.3/6.0 and there is a 300zx around the corner thats been sitting for a few years and needs motivation. My thinking isnt that of an import, but with the price difference and if it would be able to rev/faster higher(read quicker spool) than I would think it would be a fun drive.
A 6.0L block with lq9 or LS2 pistons and a 4.8 crank/rod assembly would be a nice combo, almost the same configuration as an early 327 except with the much longer rod ratio. Tailor your head chamber size to the compression you want for your application (N/A or Boost
).Due to it's low piston speed and increased piston dwell, this combo should respond well to turbocharging, especially with two small turbos sized for around 2.7L each.
Im not sure what piston dwell is but ill look it up. Dont know much on the technical side but im open to learn plenty.
~Cole~
