LS3 + CAI/Tune at Sacramento 12/15
Old Dec 16, 2007 | 12:25 AM
TractionTroubles's Avatar
Default LS3 + CAI/Tune at Sacramento 12/15
Best times:
Had alot of fun. Got to race a Z06 but I lost traction and had to let off. He ran a best of 11.2@125 1.7 60'(Stock + DRs)
Nice 55* weather today. Not quite Atco but damn close.
Old Dec 16, 2007 | 02:38 AM
LS1LT1's Avatar
Thumbs up
Originally Posted by TractionTroubles
LS3 + CAI/Tune
+ a 160 degree thermostat and the free cold air/opened shroud mod, just a little reminder in case you forgot you had those as well.
Congrats, car is really fast for so few mods.
Old Dec 16, 2007 | 02:49 AM
BayAreaSS's Avatar
Congrats. Thats moving for sure!
A friend of mine went today as well and told me the track was pretty good today. Wish i would of went!
Old Dec 16, 2007 | 01:56 PM
camscam02's Avatar
congrats i saw that run! track was ok for a little bit then went away.... but it was a good day non the less!
Old Dec 16, 2007 | 02:52 PM
bad2000z's Avatar
Good times! Does anybody make a stall converter for new new A6's?
Old Dec 18, 2007 | 08:22 AM
Ragtop 99's Avatar
Yank does. I believe the viglante is available too
Old Dec 18, 2007 | 01:45 PM
I really want to avoid converter and headers because of drivability on the street, noise, and smell. Maybe a small cam that is nearly unnoticable...
Old Dec 18, 2007 | 03:20 PM
Bird_Of_Prey's Avatar
A converter would do wonders for you and not really affect street manners. That new vette is flying! Hope Santa brings me one!
Old Dec 18, 2007 | 08:25 PM
Ragtop 99's Avatar
A couple thoughts.
1) a small converter 2800 - 3000 stall doesn't add that much slop to the feel. To take out some of the slip, you can raise part throttle upshift and downshift points a couple mph. It will feel pretty close to stock.
2) I've done two different cams with stock manifolds on my SS. The first, a 210/222 112 110 made great torque down and was a snap to tune. It would work with the stock idle speed of an automatic. It would not be that hard to spec a similar cam to the LS3. I've attached a scan of the dyno (sorry about the quality). It was done on a mustang dyno so the numbers low, but look at the torque curve. Its the kind that would knock .1 - .2 off the stock stall's 60'.
Attached Thumbnails LS3 + CAI/Tune at Sacramento 12/15-stock-exhaust-cam-only-dyno.jpg
Old Dec 20, 2007 | 12:04 AM
What about the second cam?
Do you know what the stock stall is?
Old Dec 20, 2007 | 01:42 AM
No clue what the stock stall is, but I'd throw it out and get at least a 3600rpm model in there.
Old Dec 21, 2007 | 05:16 PM
Ragtop 99's Avatar
My second cam is the 214/230 111 109 cam. I used Thunder's 214 lobe on the intake (~.600 lift) and a Xer lobe on the exhaust. It had no improvement on bottom end compared to my first cam, but the midrange and top end were better. For your LS3 and given that you want very clean operation, I'd look at a 218/230 115 112. That would bring your overlap back to -6 from 0 on my 214 cam. Combined with the extra displacement and compression of an LS3, it should run nice. If you want it even more like stock, go one size smaller and use a 116 LSA and 113 ICL.
Old Dec 25, 2007 | 12:39 PM
ctsls6's Avatar
Great Times
Old Dec 25, 2007 | 10:51 PM
studderin's Avatar
nice times, for a noob
Old Dec 26, 2007 | 09:46 PM
Aye
Old Dec 27, 2007 | 10:05 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Great times, that is with stock 2.73's?
Old Dec 28, 2007 | 03:51 PM
Yeah stock 2.73 option.
Got some DRs and will go for 11.5 in Jan.
