Professional Products PowerForce Harmonic Balancer for C5-6 Corvette
Old Mar 5, 2008 | 12:27 AM
65SSZO6's Avatar
Default Professional Products PowerForce Harmonic Balancer for C5-6 Corvette
Professional Products 80033 PowerForce street harmonic damper fits Corvette with LS-1 or LS-6 V8. Semi-gloss black finish, and both the hub and the inertia ring are made of tough nodular iron on street dampers.
The Professional Products 80033 damper is identical to the Professional Products 80032, but is shorter to accommodate 1997-'04 Corvette applications with either the LS-1 or LS-6 engine. It features an integral accessory drive pulley that is the same diameter as stock. The Professional Products 80033 damper also incorporates a keyway and timing marks for those enthusiasts who want to utilize these additional features. 7.5" diameter, 11.2 pounds.
Not recommended for use above 6500 rpm.
Item is like new,was installed to balance the rotating assembly,never run on a vehicle.
$75 includes shipping
Attached Thumbnails Professional Products PowerForce Harmonic Balancer for C5-6 Corvette-professional_products_80033.jpg
Old Mar 5, 2008 | 09:37 AM
65SSZO6's Avatar
Weds AM Bump
Old Mar 5, 2008 | 11:49 PM
65SSZO6's Avatar
Thurs am Bump
Old Mar 6, 2008 | 10:18 AM
Ravenous T\A's Avatar
Will this work with an LS1 out of an Fbody? Is the crank mount different? I am going to be running Vette Acc on my motor so this may work for me.
Old Mar 6, 2008 | 02:28 PM
65SSZO6's Avatar
Yes,this balancer will mount to any LS based motor.You do need to use the Corvette accessories to use this balancer,as the F Body balancer is 3/4" further out from the block.Do you have any of the accessories from the F-Body engine you have? Might be interested in trade.
Old Mar 7, 2008 | 02:37 PM
nope, just bought this shortblock. pm me your paypal info and i"ll take that pulley off your hands
Old Mar 10, 2008 | 10:38 PM
65SSZO6's Avatar
Paypal received will ship tues AM Thanks
