LS1 Longblock and other parts.
My stock LS1 motor is still forsale.
1. LS1 longblock. The LS1 is from my 02 Camaro, after teardown and inspection there was nothing wrong with it. Will sell all parts disassembled for $1000 or can be rebuilt with new bearings, gaskets, etc. We can work with Dave from cdnperf.com to get a very reasonable rebuild engine with the options you want. Price lowered to $500
Talked to Dave at Canadian Performance. He is willing to give me a great price on rebuilding the LS1 because I spend alot on my new 402. A rebuild that includes machining the block with a hone, new rings, new barrings, new head gasket, new oil pump and new bolts is $2000. Recommend new valve springs optional valve job is $280.
So that puts us at $2500 for a complete LS1 long block with a fresh rebuild with 0k. No exchange.
Last year I called around to a few engine shops and they either didn't know what a LS1 was or wanted $4000 plus $1000 core charge.
Some more detail on what's included and what's not...
Included:
Short includes block and rotating assembly (crank, rods, pistons)
LS1 Camshaft (Good time to upgrade from the LS1 cam)
Front and Vally LS1 covers because I needed LS2 covers.
Heads with stock valves & springs. (I have comp springs for sale $200)
Included with rebuild at CDNPERF
Complete list as above with Oil pump and timing chain, barrings, gaskets.
completely cleaned, inspected, and re-assembled.
Not Included.
Oil Pan
Rear cover
Valve Covers (newer style center-bolt)
Intake manifold (I will have an LS1 manifold available)
Throttle body
Exhaust manifolds
Injectors (I have some for sale as well, would throw in the stock ones)
Accessories
2. Comp Cams 918 Valve Springs good for .600 lift with Ti retainers. 5k on these springs.$225 lowered to $175
6. Four stock 16" wheels Y-spoke with Hankook Ventus HRII H405.
P245/50R16 340-A-A $300
8. Racetronix 99-02 F-body Plug&Play Fuel Pump Power Harness $75
10. Stock LS1 MAF $100 lowered $75
11. 38lbs MSD fuel injectors, $250 lowered $200
12. Stock fuel injectors. $100 lowered $50
Pictures of almost every thing...
http://camaro.servepics.com/2007/fallsale/index.html
Included:
Not Included.
Oil Pan
Rear cover
Throttle body
Exhaust manifolds
Accessories
02 Camaro Stock air box and bellows. $20
MAF Ends $20
Nitrous controller, 2-stage, window switch, WOT switch. $100
http://nitrousoutlet.com/catalog/pro...ls.asp?group=2 6&model=86&dept=11&product_id=964
10-bolt rear end, TA girdle, 3.42, auburn posi, no brakes. $250
Strut Tower Brace, power-coated black, few chips. $50
MAF Ends $20
