>90mm throttle body- 600+ lift springs- adjustable timing gear kit- cam
before I go and buy all of this stuff new I was wondeing if anyone had this stuff lightly used and in good shape that could save me a few bucks
I need a;
-90-100mm cable throttle body
-valve springs, retainers and locks.... not picky but must support .600" or more lift
-an adjustable timing chain kit good for 4/8 degrees of advance
-a cam shaft similar to the comp cams # 54-426-11 or a stock LS3 cam will work too. if you have something close, I am looking for a relatively smooth idle, with good torque, lots of area under the curve, stock max rpm range, snappy off idle.
let me know what you guys have or if it is close but not exactly what I'm looking for I'll look into those too.
Thanks!
I need a;
Thanks!
