Single Digit Club Running 9s or quicker? Damn!
9's first time out with new setup
Old 12-02-2012, 01:28 PM
TeEnAgE pHeNoM's Avatar
Originally Posted by Aaron@Texas-Speed
Nice times, car moves out for sure!
Thanks man. MS3 works good on the spray for sure.
Old 12-02-2012, 01:58 PM
Sales1@Texas-speed's Avatar
Yessir it does!
Old 12-03-2012, 01:36 PM
Killer5.3's Avatar
Originally Posted by ryany
I have seen the car at Lena MS at one of the street shootouts car runs good...
Thanks. We hope the gear swap is gonna help the 60 ft and will allow us to run it out the back without spinning the SBE above 7000. Did you have a car there at the shootout?
Old 12-03-2012, 01:59 PM
Freerangepig's Avatar
Happy haulin'
Old 12-03-2012, 03:52 PM
02SOMWS6's Avatar
Real nice man
Old 12-03-2012, 08:24 PM
ryany's Avatar
Killer 5.3 i had the blue ss camaro there.
Old 12-03-2012, 08:59 PM
Thanks guys! Hoping for 70's next time out!
Old 12-04-2012, 09:44 AM
Killer5.3's Avatar
Ok. Yea your car moves out pretty good too, especially on motor. Just need to put the big jets in and you will be ready. I love the NBM cars. We had an '02 NBM SS hardtop. it was 6 speed though. You bringing your car to HUB for the SCSO on 15 Dec?
Old 12-04-2012, 10:25 AM
AutoRoc's Avatar
Careful not to go on the bumper with the trans brake! Happens more than it should.
Congrats on the "eazy" 9.
Old 12-04-2012, 12:34 PM
ryany's Avatar
Thanks man ye i have to get my shift points right its hitting rev limiter right now..
Old 12-04-2012, 03:09 PM
Thanks. I'm not sure what you meant by "eazy" 9?
Video added!
Old 12-12-2012, 05:55 PM
  #32
odarabla's Avatar
Originally Posted by Sommer86
You're my hero. I wonder what my built 402 will do with that same 200 shot. Hhhmmm.....
My 402ci with a 200shot has gone 9.50@140mph so far. Still yet to run it in good air though.. 3540lbs race weight..
Old 12-14-2012, 06:21 PM
  #33
Blackpanther99's Avatar
I sure bet its exciitng running 9s on your first new setup run!
Old 12-16-2012, 12:43 PM
  #34
Killer5.3's Avatar
We went back out yesterday and made about 8 passes on an .088 jet. Had traction issues most of the day ,but managed a string of 6.30 -6.40 passes with 60 ft 1.48-1.50. Was leaving with 150 -175 and ramping the rest in about 1.2 and was spinning the tires a bit through 1st gear. Turned the progressor down on last pass , launched on 100 with a .8 ramp time and ran it out the back shutting the kit off at 6900 , through the traps on motor @7300. This was our best pass of the day.
1.43
6.31 @109
9.91 @137
Setup was :
BR9EFS plug
.088N/ .044F
14 Degrees total timing
Plugs didn't look like they were getting enough heat in them. Probably gonna put some timing in it next time out and fuel ring is still little rich so may step down another jet on fuel also. Got to get the front suspension done and gear swap and should be able to get 60 ft down. 3.07 1st gear + 4.11 doesn't like nitrous it seems.
Old 12-28-2012, 07:41 PM
  #35
SF 1HOTLS1's Avatar
What trans are you running and who built it?
Old 12-28-2012, 07:43 PM
  #36
SF 1HOTLS1's Avatar
9s are nice man! Good stuff
Old 12-29-2012, 01:19 PM
  #37
4l60e. Rossler built it.
Thanks man!
Old 02-18-2013, 01:41 AM
  #38
BLWN1's Avatar
Whats next. Pretty impressive, with a 60e too.. sweet.
Old 02-19-2013, 01:28 PM
  #39
Killer5.3's Avatar
Swapping to a converter setup better for nitrous and take some gear out of it by dropping down to 3.70. Looking to run some 9.60's on the .078 jet and then work our way up on the jet and see what happens. Next mods will be front struts/ springs and some weight reduction to get it to around 3400 lbs. Our goal right now is 9.40 with stock heads and ls6 intake and then look at a better nitrous cam and some heads.
Old 02-20-2013, 03:28 PM
  #40
Lazzarus's Avatar
OP, What kind of fuel system are you running?
Quick Reply: 9's first time out with new setup
