J.W. Ultralbell help please
Hey fella's,i recently broke the case on a glide in my camaro and had to get another built.. I thought it would be a good time to get a ultrabell and be a little safer but im having some fitment issues with the converter...Everything worked fine with a stock cased glide but now with the bell,i have a 1/2 in gap between the flywheel and converter...So i know i can shim it and all that but it actually has the drive shaft tight in the tailshaft...And im not sure how much is actually in the crank...JW says its the stock length with the bell,but there is somethin going on...Ive busted pump after pump and was wondering if anyone else has had this problem??? Im using a tci flywheel part #399753...Like i said,it was fine with a stock case,but now the problem.....
