Samsel450R 9.7@135 1.39' 60 347 100 shot.
Went to a track rental this weekend with a buddys 347 H&C Formula.
Some details and things can be found in these threads
https://ls1tech.com/forums/dynamomet...p-1x7-8-a.html
https://ls1tech.com/forums/generatio...ke-system.html
Short run down is
347
AFR 205's
Custom Cam from Martin at Tick
TH400
PTC 4500 stall which needs to be loosed up, shooting for 1.2's n2o and 1.3s on motor.
12 bolt 3.73s
26" MT DR
Letting out a little early was able to go faster on a 100shot over the old PB on the old combo and 200 shot.
Short run down is
347
AFR 205's
TH400
12 bolt 3.73s
26" MT DR
track was really sketchy after the 1/8th. pot holes and gravel after the 1/4 and not much of a shut down area. was on the brakes HARD. talked to PTC they said they would help me on the converter. mentioned bumping it up to 5800
