9.11 Cam intake and turbos
Stock 2000 6.0, original pistons, rods, crank, even the rings and bearings and oil pump are from salvage yard motor, has small turbo cam, stock 817 heads with good springs. Holley high ram 160# injectors,microsquirt 2.God speed 72mm twinturbos. Running a powerglide and 3.50 nine inch
Wow. Goes to show that the "keep it simple" method seems to work. You might end up having to cut the gear back a little if it pulls through the second half like I think it might . It looks like its going to go well over 150.
Who's converter are you using?
Well my wide band still shows lean after new fuel system installed . I can see the fuel gauge staying at 55 psi when at goes lean and the motor tone changes so I lift. This all happen just past the 1/8. I am going to install the Holley HP efi so I can log what is going on.
