All motor Guys with 402-418ci whats your Recipe for 9s - Page 2 - LS1TECH
Single Digit Club Running 9s or quicker? Damn!
Thread Tools Search this Thread
Old 05-10-2016, 12:16 PM   #21
82cetuner's Avatar
im probably going to be around 3200, if I got to put the bottle on it I will. a 100 shot of n20 is alot cheeper than a whole new engine LOL
82cetuner is offline   Reply With Quote
Old 05-10-2016, 12:20 PM   #22
82cetuner's Avatar
im still making changes so no track times yet, I removed quit a bit of weight
MWC front and rear bumper support
MWC k member and A arms
Removed all Parking brake hardware
Strange rear Drag Brakes
AC Delete Plate to remove rest of AC stuff
Also added weight back in with MWC roll cage
but switching to viking coilovers from the Koni, Strano Setup and added a Drag bar so should see some improvment on my 60ft. I will keep you guys updaded
Old 05-10-2016, 12:33 PM   #23
Rise of the Phoenix's Avatar
It should be possible with what you have. ZMG00camaross on here runs 10's on a stock cube, non forged, 346ci setup with cam only and a FAST setup (stock heads), M6, in a 2000 Camaro SS with weight reduction.
Rise of the Phoenix is offline   Reply With Quote
Old 05-10-2016, 04:43 PM   #24
82cetuner's Avatar
oh I know smaller cubes have gone alot faster than me, my car has just never been setup specificly for drag, im leaning towards that route now, the motor makes good horsepower but tops out at 6300. plus its a 6 spd. i know a good stalled auto would probably already get me close to the 9s. car has ran a mid 10s as it sits, but i had to run rear tire pressure really low to get it to hook, hopefully all the changes and being able to run higher psi in the rear will take off a few more tenths.
Old 05-12-2016, 09:46 AM   #25
Launch's Avatar
You want my honest opinion, to run good #'s naturally aspirated, ditch the LS3 heads and go to a good Cathedral head, like trickflow or mamo AFR, or use LS7 heads..
Launch is offline   Reply With Quote
Old 05-12-2016, 01:27 PM   #26
82cetuner's Avatar
if I spend more money on Heads I will spend it on heads I can switch over for boost. maybe some afr 245s or 255s something for a future 427lsx setup. right now im not willing to invest 4k into a good set of heads when I can get a built stalled auto and gain more than the heads would give me
Old 08-18-2016, 01:00 PM   #27
crossbreed383's Avatar
Quote:
Originally Posted by DietCoke View Post
Sure, at 2500 pounds.
Car weighed hair under 2900 actually
And engine was.sold to a gentleman in Jersey
Ran 8.58 1st time out in testing at Englishtown
Just wanted to clarify
crossbreed383 is offline   Reply With Quote
Old 08-18-2016, 01:17 PM   #28
Major Shart's Avatar
My car went 10 flat @136mph with a 6 speed and not too much weight reduction. I'm sure with some practice or better air it would have gotten in the 9's. That was with the previous owner, also on a 150 shot and using stock (BTR ported) 317's, Vic Jr. and that horrible elbow.
I have changed a ton and hope to get into the high 9's on motor alone. I added a TH400 with a brake, 4150 FAST throttle body and bumped the compression up to 13:1. I have also done some things to lighten it and added Viking da coil overs. Previously it ran on stock stuff with comp rear shocks.
After I get about as much as I can out of it on motor I'll start adding the juice. Looking for a total of about 400-500 hp of spray.
Major Shart is offline   Reply With Quote
Old 08-19-2016, 07:45 AM   #29
sillysspeed's Avatar
OP The weight reduction is gonna help you out a lot. I'm in the 10's and dropped over 2 tenths and 2.5 mph over my previous best with very similar weight reduction this past winter. If you don't want to tear into your nice engine I'd cut down or buy the shorter fast runners. If your in mid 10's now and could get a few tenths out of weight reduction, a tenth or 2 outta intake and get some good air you would be real close
sillysspeed is online now   Reply With Quote
Old 12-22-2016, 05:41 AM   #30
Firebirdmuscle's Avatar
82 what did you ever do with your car this fall/winter?
Firebirdmuscle is offline   Reply With Quote
Old 01-21-2017, 08:02 PM   #31
HighspeedLean's Avatar
You act like liteweight is a bad thing.I converted my dominator back to a 750cfm to slow it down to run the local 9.60 index.
HighspeedLean is offline   Reply With Quote
Old 02-15-2017, 08:57 AM   #32
handyandy496's Avatar
Jmo.. There is something wrong with your valve train. There are plenty of ls3 headed stroked ls2's shifting at least 7000 rpm.
Over spring it a bit, 105 wall pr's , short travel, low lash or solid lifters. I shift at 7000 with ls3 gmpp's out of the box, moral short travel lifters w .750 roller, stock rockers, 235/250 115+5. very street able.
handyandy496 is offline   Reply With Quote
Old 02-19-2017, 04:34 PM   #33
shouldnt u keep the fuel injection if your goona be streeting alot? I always thought u got way better mpg and tunability with the fi......unless im wrong
Floorman279 is offline   Reply With Quote
Old 02-19-2017, 08:59 PM   #34
82cetuner's Avatar
mainly I had to repair it, i live in louisiana where we flooded out in october, car was under water for 2 days. but i saved it and got it running after a week, took alot of time replacing all the eletronics on it. have been able to make 2 passes on the new suspension setup and weight reduction but never had a good run. still need to make a few small repairs. I am now switching to a 4l80e also and probably a 150 shot of nitrouse. idk if I mentioned it before but before flood I did full viking coilover, full tube k memeber up front, and some weight reduction.
Old 03-13-2017, 10:13 AM   #35
82cetuner's Avatar
got any info on this? this is a definet mod I need to do
Old 03-13-2017, 10:22 AM   #36
Tuskyz28's Avatar
Did you ever decide on heads for your build?
Tuskyz28 is offline   Reply With Quote
Old 03-13-2017, 11:01 AM   #37
82cetuner's Avatar
ive decided to not really mess with the engine. i want to go procharger down the line now that the car is capable of handing over 1000hp. but i dont trust the 418 block for that. i will end up doing a lsx block at some point. im hoping the 4l80e with transbrake will get me a few tenths and once its dialed in that way I will throw a 150 shot on it for now. losing everything in the flood halted alot of the big plans for it for now. im only doing the 4l80e cause its only a couple thousand after selling off my t56 and building the 4l80e myself
Old Yesterday, 02:27 PM   #38
Mike Morris's Avatar
Quote:
That plus Mamo MSD intake if you are going to spin it high.
Mike Morris is online now   Reply With Quote
Related Topics
Thread Thread Starter Forum Replies Last Post
Which 102mm or 105mm throttle body is best?? Updated w/dyno sheet & video neblackshirts Generation III External Engine 36 03-19-2017 05:39 PM
416 cam advice! lastlumina Generation IV Internal Engine 15 03-18-2016 11:58 PM
600whp? 434 TFS245s.. Snyper Generation IV Internal Engine 30 02-22-2016 08:16 PM
408 PRC 247 251/259 results VandykeT/A Dynamometer Results & Comparisons 34 11-20-2015 10:32 AM
LS1 results on 235/239 .621 .624 112 Black01Z28 Generation III Internal Engine 10 03-16-2015 05:42 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
    Get answers from community experts
What's your question?
Send
