about time - LS1TECH
Single Digit Club Running 9s or quicker? Damn!
about time
Thread Tools Search this Thread
Old 07-30-2008, 06:21 PM   #1
Default about time
Another long weekend, and finally a 9sec
Still not impressed, as basically the only reason its doing it, is I was using ET Streets ( 26x11.5x16" )
The car, while it does feel good, has performed better. Its just lost so much over the latter parts of the track compared to how it used to perform.
60ft..........1.55
330ft........4.21
1/8...........6.41 @ 113.83mph
1000ft.......8.23
1/4...........9.85 @ 144.75mph
Also did 2 x 9.99s runs with lower mph. Would have got some more, but the boost pipe kept blowing off the supercharger.
Still pump fuel + 70/30 meth/water
http://]Another long weekend, and fi...or MT DR's
Car ran well all weekend.
At an event on Sunday at an airfield, I ran 181.9mph over a standing kilometer ( 1000m ) on road tyres ( Toyo 888's )
By comparison...best 1/4 at that event was 11.15s !!!!!!! Absolutely no traction at all, either on 888's, or MT DR's
Basic spec...
383 LS6 block
JE Pistons, Callies rods, Eagle crank, EPP cam, TFS 225cc heads, 1.7 YT Ultralights.
Carb intake + elbow, 85mm TB, custom 2" headers with dual 3" exhausts, dual 044's, DTA S80Pro ecu, Vortech V7 YSi, custom 12 rib drive, custom FMIC
T56 gearbox by Sixspeedsinc, stock gears, cryo'd, uprated shifty bits, Viper o/p shaft. Textralia triple disc
Ford 8.8" rear end, Torsen diff, MW 31sp axles, 3.55
stevieturbo is offline   Reply With Quote
Old 08-23-2008, 01:57 PM   #2
99.9percenter's Avatar
Quote:
Originally Posted by stevieturbo View Post
Still not impressed
What is going to take to be impressed?
99.9percenter is offline   Reply With Quote
Old 08-23-2008, 02:17 PM   #3
I previously ran mulitple low 10's, at 148-149mph ( 10.04, 10.07, 10.2x etc etc on 255/50x16 DR's )
At 144mph traps, my car is a LOT slower in terms of power/acceleration that it has been in the past.
As I say, the only reason it was run a 9 these times, is due to using the ET Streets. The car is not performing as well as it should be.
If it was running as well as before, and getting the same launches the ET streets allow.....I'd say mid 9's would be do-able.
Then I might be impressed
Related Topics
Thread Thread Starter Forum Replies Last Post
No 12's (yet) But New PB transamtom Drag Racing Results 14 04-10-2011 07:38 PM
Got my 11s... **CAM ONLY** TORCHD 02 TA 11 Second Club 53 09-23-2009 01:15 AM
Another trip to the track completed! Green3spd LT1-LT4 Modifications 12 04-13-2009 01:10 PM
TTV6 new pb Tim King Single Digit Club 13 08-15-2007 11:44 PM
My First 12! Took six runs. DevonsZ 12 Second Club 6 07-30-2005 07:51 PM
Tags
383, ls1tech, ls6, supercharger, v7, ysi
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
