carbertated smalll block in a camero
No it will not, either make your own motor mounts, get an aftermarket cross member with the small block mounts, or use motor plates. You will also need to trim the cowl to clear the carb and dent in the firewall to clear the distributor.
You won't need to dent the firewall.
You'll also need to figure out a new fuel system, trans, brakes, all your gauges, and accesories. You can get around some of this by keeping some of the stock electronics.
We need some more info on what your plan is for the car. It's not as easy as a straight motor swap.
~Jim~
~Jim~
