Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
tool for ARP flexplate bolts
Old 03-03-2010, 08:51 AM
bww3588's Avatar
Default tool for ARP flexplate bolts
i have a 91 chevy 350 that im trying to use ARP 12pt flexplate bolts on and i cant get a box end wrench or a socket on the bolt to tighten it up. the centering flange on the crank for the flexplate is too close to the bolt. i tried machining down a 3/4 socket to fit in there but it just broke. wtf am i supposed to use?
Old 03-03-2010, 08:55 AM
31camaro's Avatar
they are 12 point heads
Old 03-03-2010, 08:58 AM
bww3588's Avatar
i know this....im saying...no socket or wrench will fit on the bolt because the crank flange sticks out too far.
Old 03-03-2010, 09:00 AM
31camaro's Avatar
i have the same bolts you have, and i tightned them with a short well 12 point standard socket, i cant remeber the size though
Old 03-03-2010, 12:34 PM
bww3588's Avatar
i used a 3/8 drive 3/4 socket and nothing doin. i couldnt get the side of the socket between the bolt head and the crank flange. this is the only thing keeping me from putting it on the dyno at school...i really hate to use channel locks
Old 03-03-2010, 02:44 PM
6 & 8 Second Club
mrdragster1970's Avatar
WOW, that's weird. I've put a ton of flexplates on, and never had that issue.
I can't believe a standard socket won't work??
Wrench's don't work, but I torque mine down with a socket.
I would definitely use a socket & tap it on or grind/machine it down a little to get it thin enough??
Please do not use channels.
Good luck.
Old 03-03-2010, 02:59 PM
bww3588's Avatar
Good luck.
i was kiddint about the c-locks, but i already tried machining down a socket and it just broke when i tried to put any sort of TQ to it. it was a good Snap On socket as well....
im ready to throw them thru ARP's front window and use the stockers. this isint any high HP build, but i just want good quality stuff on it so it lasts as long as the stock engine did...200k.
Old 03-03-2010, 05:11 PM
bww3588's Avatar
i measured between the apex of the bolt and the crank flange was .055" something doesnt seem right....
Old 03-04-2010, 01:55 AM
6 & 8 Second Club
I know, I was screwing around also.
At this point, I would go back to a 6 point. I've used stock bolts on 600-700 HP.
ARP & Mrgasket on anything above that.
Old 03-04-2010, 06:59 AM
bww3588's Avatar
i think thats what im going to do. its just a pain in the *** when ARP sells you something that hardly does its job. i mean im sure they do their job, but getting it to work is another story.
Old 03-04-2010, 10:32 AM
6 & 8 Second Club
I've never used a 12 point, so I'm not going to say if it's just too damn tight??
The 6 point is tight, but I personally have never had one that damn tight??
Obviously the biggest head possible will hold better, but geesh, you have to get a tool on the damn thing??
Good luck,
Quick Reply: tool for ARP flexplate bolts
