New 383 Burning Oil
New 383 Burning Oil
i have a 383 camel hump heads 488 lift cam rpm air gap manifold motor has less then 600 miles on it and the oil is dark already and was 2 qts short the other day
what do you think the problem is?
i pulled a spark plug and it was dark brown smelt like burned oil
ive only changed the oil once since its been built
Make sure your intake gaskets aren't leaking and sucking in oil from the lifter valley. Before I bolt an intake on for the first time, I like to take one standard thickness gasket and bolt on one side of the intake only. Then I can measure the gap at the front wall and also on the opposite intake face. This will tell you a lot of things about thickness of gaskets you need, overall gap at the end walls and if the intake surface is parallel to the head surface. This step was recommended to me by a professional builder and he was absolutley right!
A lot of people who have been building engines for a long time like to use extremely tough rings in there builds that really take a long time to get seated and if the bores aren't in great condition they sometimes never do seat properly. I would make sure you have no leaks and wait until it had a few thousand miles on it before I would get to worried about it.
alright i guess just seems like 2qts of oil in less then 600 miles is kind of bad ... and is there anything i can do to help it ? im using 10/40 mobile 1 oil i still have to have my timing done really bad should i change out my spark plugs or wait a while and why would the oil be black already?
at idle it doesnt smoke when im driving it doesnt smoke when i floor it it smokes a little could be because its running a little rich too though
With oil on the plugs, I would still be looking at the intake gaskets. The gaskets may be allowing oil to pass and not water. Another culprit could be the PCV system...what are you using? And, as mentioned above, ring seal might be a problem.
Im running a normal PCV valve to the vacume on my carb intake gaskets seem to be fine from what i can tell i tried to tighten them and they were already tight my guess is ring seal like you guys said or valve guide or valve seals ??
ill try to drive my car around a little more to see if maybe it gets better i guess im just worried
no vacume is good and car has a lot of power it runs really good just noticed that it was burning oil so now im worried that i have a problem esp because the motor only has like 600 miles on it
Dude delete the pcv system and put a nice evac kit on it. To hell with sucking that oil and what not through your brand new engine and intake. When you cam a car and the vaccume changes it really mess's with the pcv operation. I personally dont like pcv valves on a performance engine.
i dont think it really matters anyway my oil is dark and its burning oil anyway =[
i need to figure out what the problem is i really hope its just the heads that need to be fixed
You could get an oil seperater to put between the PCV and the intake. I just ordered a Steeda one. I popped my intake off last night because of an external oil leak. Turns out my cheap Mr. Gasket intake gaskets are shot! They looked like wet carboard. I have never seen that before! It explains my drop in idle vacuum.
Pull that intake and look at the gaskets first. After that, I would be looking at the valve stem seals. Finally, I would do a leak down test to check the rings and valve seats.
i honestly dont think it has to do with the intake gaskets i have no leaks AT ALL gaskets look perfect and dry once i sell this other motor i have and have some extra money im going to replace the heads and intake manifold for more power and better MPG (Vortec heads & vortec style rpm air gap manifold VS camel hump heads) at that time ill do a leak down test too how do you do that anyway?
I am not saying you have any of these just telling you what a leak down test does.
