Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
Getting closer
Old 10-24-2010, 10:52 PM
ROBS SS's Avatar
Default Getting closer
update on the ride.....
got the brake lines finished up and the motor in ....time to have some headers made in the next week or so and finish the wiring....here is a few pics enjoy
Old 11-10-2010, 06:20 PM
QwkTrip's Avatar
Nice. Are you not going to use a conventional distributor?
Old 11-10-2010, 10:01 PM
ROBS SS's Avatar
using a crank trigger set-up
Old 11-11-2010, 06:59 AM
tektrans's Avatar
man that's nice. Who's mid plate is that? What block did you use? How many cubes?
I just bought a 632 (Merlin III block), gonna stuff it in my TA.
I'm going with a front belt and distr. drive set up.
Old 11-11-2010, 05:25 PM
ROBS SS's Avatar
its a madman front/mid plate mid plate has been trimmed up to fit, its a dart little M block and its only 393ci
Old 12-16-2010, 06:02 PM
ROBS SS's Avatar
update....got the headers done...got some mufflers on order , then off for coating ,now time to wire it up!
Old 12-17-2010, 06:23 AM
cambirdracing's Avatar
Your carb is on sideways, haha.
Looks nice. Makes me jealous.
Old 12-17-2010, 10:13 AM
BACKAGAIN's Avatar
That looks sick!!
Old 12-22-2010, 07:12 PM
ROBS SS's Avatar
thanks guys, I hope to have it running the first of the year so i can do some testing
Old 12-22-2010, 07:56 PM
In-Zane Moderator
ZONES89RS's Avatar
What made you go with so little cubes?
Old 12-23-2010, 04:27 PM
ROBS SS's Avatar
there is weight breaks in many classes out here, and sb2's dont really need big ci's to make big power
Old 02-22-2011, 10:38 PM
ROBS SS's Avatar
well getting a few things done...got the alt and vaccum pump mouthed along with the overflow tanks and fan....gonna weld some -16 AN fittitings on the radiator and get all the lines made....looks like after this weekend will just need to be wired...heres a few pics
Old 03-08-2011, 06:05 PM
ROBS SS's Avatar
get to start on the wiring this next week, just got the headers back from getting coated.....they look shinny!
Old 03-08-2011, 08:14 PM
Oldsmobility85's Avatar
Looks great. So do those beadlocks. What kind of driveline setup are you using and how much converter?
Old 03-08-2011, 08:17 PM
87silverbullet's Avatar
With your car being black and putting in a sb2 smallblock it reminds me of one of the old Pinks shows that had the same setup. That guy gave a big block car something like 8 cars and still hunted him down!
Good luck with the build. That is going to be one nasty ride when you are done!
Old 03-08-2011, 08:34 PM
ROBS SS's Avatar
im running a glide....the converter is a neal chance 8" 6500 stall
Old 03-08-2011, 10:14 PM
Bolt together style converter? 9" out back I assume? Should cut in the mid 1.2x 60ft range I would imagine.
That millers race engines sb2 camaro was fast as hell.
Old 03-08-2011, 11:13 PM
ROBS SS's Avatar
no bolt together...its ther regular converter....and the car has a strang 12-bolt in it (12-bolt was in the car when i got it)
Old 03-09-2011, 05:14 PM
ROBS SS's Avatar
just got the last of the lines done, went ahead and put AN fittings on the radiator and got a new water neck with a AN fitting ...painless wiring harness on order hope to get started on it this weekend...
Old 03-09-2011, 09:34 PM
warp10's Avatar
I'm in love.
Quick Reply: Getting closer
