DIS Ignition System Kit for L-98 - LS1TECH
Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
Thread Tools Search this Thread
Old 04-09-2012, 06:09 PM   #1
Default DIS Ignition System Kit for L-98
I am looking for a DIS Ignition kit for an L-98 engine. I do not want a waste-spark system but a true coil near plug.
Thanks
speedwrench88 is offline   Reply With Quote
Old 04-09-2012, 07:02 PM   #2
87silverbullet's Avatar
Quote:
Thanks
Here you go. Gets rid of the chip style pcm also.
http://www.eficonnection.com/eficonnection/default.aspx
87silverbullet is offline   Reply With Quote
Old 04-10-2012, 09:26 AM   #3
Default Dis l-98
Silver Bullet,
Thanks for the reply.
I looked @ this system and it looks very nice for the LT-1 but a little crude for the L-98 as I have to leave the old dist in place.
I am looking for a more compact system.
Thanks
Old 04-10-2012, 01:22 PM   #4
Silver Bullet,
Thanks
I don't know if you are going to find one.
You have to get cam signal from somewhere and LT cars its in the opti, on L98 cars its on the dist.
I could care less about the dist being back there. I like the tunability of a flash style pcm. Thats the reason with going with this style system, so you can just bring it to one of your local tuners or tune it yourself with HPT.
All in all what I'm trying to say is that the good on this outweighs the bad.
Old 04-10-2012, 02:17 PM   #5
Default Dis l-98
Silverbullet,
Thanks again but I have seen a couple of systems that have the ECM incorporated into the top of a distributor housing with the coil harnesses coming out the side.
They use the same technology that AEM, Mallory, and a couple of others use with there EPM (Engine Position Module) were they pick up both cam & crank signal in the distributor housing for there EFI systems.
Unfortunately I cannot find the companies.
Thanks again
Old 04-11-2012, 12:31 PM   #6
Silverbullet,
Thanks again
That's almost like the turbo regals of the 80's. The AEM EPM might be compatible with the EFI connection setup.
Old 04-19-2012, 02:10 PM   #7
DYING BREED's Avatar
eficonnection does an ls style which is great and quite tunable, and there was a company(cant remember) using the grand prix/gtp) small coil packs for the wires/plugs.. i think the LS one is awesome, it combines the old school reliabilty/power capability of a gen 1 sbc and the tuning of these new school ones.. 1 2 punch imo.
DYING BREED is offline   Reply With Quote
Old 05-15-2012, 11:48 PM   #8
MSD "used" to make a CPC sytems for SBC. I think it has been discontinued. May want to call and ask them.
Suaveat69 is offline   Reply With Quote
Old 05-16-2012, 05:26 PM   #9
Another vote for EFI Connections....
Bilster is offline   Reply With Quote
Old 05-18-2012, 09:57 AM   #10
Quote:
I think the company you are talking about is Delteq. They used the Cadillac ignition module for the v8 engines.
Related Topics
Thread Thread Starter Forum Replies Last Post
97 lt1 ignition upgrade? 8 coils mayby massen1981 LT1-LT4 Modifications 8 11-03-2015 09:57 AM
sbc electronic ignition system t6378tp Small Block & Big Block Chevy Specific 4 02-14-2012 10:49 AM
LT1 boost ?: Delteq or Mallory DopdBrd Forced Induction 7 10-30-2007 12:17 PM
What is drysump, and the the advantages and disadvantages? Gordon0652 New LS1 Owners - Newbie Tech 5 12-20-2006 02:34 AM
Tags
aem, chevy, chevydistributerlessignitionconversionkit, compatible, conversion, dis, distributorless, engine, epm, ignition, kit, kits, mallory, module, position, sbc, system
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
