vortec heads with hot cam on gen 1 sbc - LS1TECH
Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
Thread Tools Search this Thread
Old 04-22-2012, 07:22 PM   #1
Default vortec heads with hot cam on gen 1 sbc
i have a 1977 generation 1 350 that is now a 383 stroker.
i want to do the vortec head and lt4 hot cam combo that i have heard so much about but i am wondering if it is possible with my era of engine.
is the cam bores compatible with a hot cam?
is the vortec heads compatible with the 1977 350?
what machining if any will i need to use the vortec heads?
thanx for the help
chase
any other misc information is helpful
chaseocon is offline   Reply With Quote
Old 04-22-2012, 09:13 PM   #2
87silverbullet's Avatar
That swap is going to cost a chunk of change. You will need retro-fit roller lifters a cam button to hold the cam in. Vortec heads are only good to .450 lift unless you already have them modified.
87silverbullet is offline   Reply With Quote
Old 04-22-2012, 09:34 PM   #3
zraffz's Avatar
One more thing, if you don't have a set of vortecs laying around it's not really worth it. I had a set with 275,000 miles that needed to be looked over/cleaned up. With parts and labor it's about $700 to run a cam around the specs of the LT4 HC. If i had to pay for the heads, I wouldn't have used them unless they were in great condition.
zraffz is offline   Reply With Quote
Old 04-23-2012, 03:01 AM   #4
ok i was just planning.
what other 64 cc heads/cam/other valvetrain combinations would you recomend?
and thank u
Old 04-23-2012, 05:01 PM   #5
Depends on your pistons, don't want to have domes to make 14:1 with those heads...
I don't think you need to worry about machine work - those heads should fit any 350 based block.
That cam would need aftermarket lifters to work - make sure you check out lifter manufacturers to make sure of compatability with a newer style roller cam like the HOT meant for L98/LT motors.
Paul Huryk is offline   Reply With Quote
Old 04-23-2012, 08:37 PM   #6
the pistons are kb hyper pistons im looking at 10.5:1 compression.
is there a more economical way to get that kind of power. its a street/strip car so it doesnt have to be to radical just a fast street car.
thanx
Old 04-23-2012, 09:10 PM   #7
zraffz's Avatar
It depends what you are trying to do power wise. Scoggin Dickey makes a set of Vortec heads for right around the $700-$800 mark that will work with the LT4 HC.
You have to choose if for a few hundred more you want to go with something like Trick Flows and make more power. I didn't realize my Vortecs were going to get so pricey, like I said I had them laying around. If I knew I'd hit the $700 mark, I'd probably have hunted for a set of used AFRs for about $1,000.
Related Topics
Thread Thread Starter Forum Replies Last Post
Need help tuning my 350 Vortec with a LT4 Hot Cam ZQ8 Blazer LT1-LT4 Modifications 16 08-28-2012 01:36 PM
help with picking a cam for my vortec headed l98 350!! ONE-BAD-Z Small Block & Big Block Chevy Specific 17 01-25-2011 02:08 AM
350 vortec cam help BIG D'S 2000 RAM AIR Small Block & Big Block Chevy Specific 2 12-07-2009 09:51 PM
Vortec heads with Hot cam drpedgmc Small Block & Big Block Chevy Specific 16 06-11-2009 06:57 AM
1996 Vortec compatible with LT1? Silverado_L31 LT1-LT4 Modifications 3 03-04-2005 10:02 AM
Tags
350, 383, cam, conversion, gen, heads, hot, lt4, machine, money, roller, sbc, stroker, virtec, vortec, work, worth
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
