new setup for my 454 help! - LS1TECH
Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
Thread Tools Search this Thread
Old 08-15-2012, 12:25 PM   #1
Default new setup for my 454 help!
so i had my 454 built by shafiroff over 25 years ago.. its a 454 bored 30 over.. i forgot all the numbers like cam size and what not.. but i want to start getting into it again and put a new top end combo together... i know i have 11 to 1 pistons in it so i deff need a oval port open chambered head. and i would like to stick with the exhaust ports factory size as well... what heads/ intake etc should i go with? and whose big n good in speccing bbc cams? i got a custom cam specced for my ls383 and that things shines so want to do the same with my bbc... please help with whats new and whose hot in the game now!! been outa this for a long time
SStressin is online now   Reply With Quote
Old 08-16-2012, 11:48 AM   #2
cambirdracing's Avatar
I have recommended these heads for every big block oval port build;
http://www.jegs.com/i/Brodix/158/2061000/10002/-1
Not only do I have a set on my wifes 489, but they work great and bolt on with no modifications. You really need to check the height of the piston dome b/c 11:1 really doesn't mean squat. BBC heads come with all different combustion chamber sizes.
cambirdracing is offline   Reply With Quote
Old 08-18-2012, 11:31 AM   #3
okay thanks probably going to go with those heads.. tearing apart the motor soon to get all specifics cc size dome size etc... forgot all the info over the years :/ whose good in the big block world to spec a custom grind cam that would work and fit in my setup?
Old 08-20-2012, 02:25 PM   #4
http://bulletcams.com
Only the best will do
Old 08-20-2012, 07:33 PM   #5
BassProCamaro97's Avatar
Get all the facts before you start looking at heads. You compression is based on the sum of the parts not just the piston. Figure out what your stroke, piston shape and piston CC is first. Then select a head and gasket which gets you into your desired compression zone.
That being said I love Brodix heads. Every motor we've put together has them. I hear good things about Dart and AFR as well but I have no hands on exp with their heads.
Good luck,
~Jim~
BassProCamaro97 is offline   Reply With Quote
Old 08-20-2012, 09:55 PM   #6
Good luck,
~Jim~
Thats what im goin to do. Just trying to get an idea of whats the best out there since i been outa the game for over 20 years. In fall/winter going to pull stuff start taking measurements and sizes and start pickin out stuff
Old 08-27-2012, 05:40 PM   #7
SS10Tech's Avatar
I am a large fan of AFR myself, especially their CNC'ed models. They work great right out of the box with no need to venture into porting services. They just work and work well. Tony has also put alot of time into the design of them, so the R&D is exceptional.
www.airflowresearch.com
SS10Tech is offline   Reply With Quote
Related Topics
Thread Thread Starter Forum Replies Last Post
FS: Custom Grind LS3 Cam JBruno88 Parts Classifieds 6 01-26-2016 04:04 PM
bbc 482 onebadblazer92 Small Block & Big Block Chevy Specific 2 10-20-2015 08:25 AM
E85 for 454 BBC carb "MAC" Small Block & Big Block Chevy Specific 2 11-10-2014 05:44 PM
1977 Chev Monza Spyder LSX454 underway 454spyder Conversions & Hybrids 41 12-20-2012 06:55 PM
Street car to track only fbodygod Racer's Lounge 11 12-27-2011 11:42 AM
Tags
30, 454, block, bored, cam, chevey, chevy, custom, exaust, good, grind, maxh, pistoncam, size, small
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
