Starter issues please help! - LS1TECH
Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
Thread Tools Search this Thread
Old 08-30-2012, 01:46 PM   #1
Default Starter issues please help!
I just bought a 1987 camaro with a 383, brand new heads cam crank intake....the works.....the first day i had it i got to register it went to go start it and it would not start, wouldnt even attempt to as if there was absolutely no power.....but there was.....i had it towed home inspected the issue and one of the wires that runs from the cylonoid to the starter was melted in half. I took the starter apart found iron wool in the starter but still put the wires back together and tested it outside the engine and it worked, but when i would hook it up to the engine and try starting it smoke would come rolling out and it would burn the wire up again. NOTHING is shorting all of the negatives and positives are where theyre supposed to be and not touching. Could it be that the compression is high in this motor and the starter isnt strong enough so it keeps frying itself up? Could it be the battery? (700cca) The starter that is on it now is a performance starter to, the engine still seemed like its always had problems turning over since day one. It just turns so slowly and its never an instant fire up. Im going to order a more powerful starter soon to see if that is the problem but i want an opinion first. Any advice is helpful.....thanks
Demojr90 is offline   Reply With Quote
Old 08-30-2012, 09:06 PM   #2
SS10Tech's Avatar
Do a compression test on a few cylinders and find out what your cranking PSI is:
http://www.summitracing.com/parts/ANM-CP7827/
Next i would get another starter. The one you have may work on the bench, but the stator windings have been compromised/damaged due to being shorted from overheating. Do not crank on the new starter as you will simply overheat the stator winding once again, short out a starter solenoid, or overheat the wiring just as this one shows.
Verify that the wiring to the new starter solenoid is correct with a decent 12V keyed ignition hot source.
Verify TDC and then verify your timing curve in order to make sure it is firing correctly.
Next i would question cam installation. Get a degree wheel and degree the cam. Writeups do exist on the forum and also on the internet to better help you out here if needed.
From here if everything checks out OK then the only other thing that comes to mind is a possible clearance issue with the motor just being reassembled.
SS10Tech is offline   Reply With Quote
Old 09-01-2012, 04:06 PM   #3
The only reason why i don't think the timing is off or that anything is wrong with clearance or the cam is because the car started the first couple times fine, i mean it turned over very slowly but it did start and boy did it run reeeaaallllyy good. My thing is that it just seemed like the compression was just to high for the starter so i ordered another one, another thing is that when i took a look at the bottom of the engine the oil pan was leaking out onto the starter, i already got all the parts ready to fix that, but i think that might of fried the starter as well maybe even perhaps from the very beginning. Even after i rigged up the old starter to see if it would work it did for a short bit and the engine was cranking ready to start(the only reason why i think it didnt is because i might of flooded it with gas trying to start it the first time it broke down)... but it did turn the crank very well, then it over heated and failed again.
Old 09-05-2012, 05:04 AM   #4
bww3588's Avatar
Is the starter shimmed correctly? I've had the same problem before. It worked fine on the bench and when it did find the nuts to turn over, it was very slow. Turns out the starter was too close to the flywheel and binding up.
bww3588 is offline   Reply With Quote
Old 09-05-2012, 10:05 AM   #5
1 FMF's Avatar
can you take a picture of the starter, or post make & model of it?
there are two types of starters, the older direct drive style which were bigger and heavier and less powerful on the older engine and they bolted to the bell housing with 2 or 3 bolts parallel with the starter (running front to back in regards to the engine). The newer style starters are PMGR (gear reduction) and are smaller but the gearing allows them to work better and their bolts are perpendicular to the starter going thru the nosecone of the starter. For the pmgr starters the "solenoid" on those requires 10-20 amps of current so you generally need a relay on that so it gets enough power. same starter that's on my ls1 is on my boat engine and i ran into this problem on the boat where i kept blowing solenoids until i replaced a faulty slave solenoid mounted elsewhere on the motor. I never had smoke or burned up wires or anything.
What you can also do is just remove all the spark plugs and disable the fuel and see how the motor cranks, it should spin rather easy. if the starter can't do that then...
1 FMF is offline   Reply With Quote
Old 09-07-2012, 01:11 AM   #6
LilJayV10's Avatar
Try backing the timing off. I have seen nose cones of starters blow apart because of incorrect timing.
If you are burning wires up its because its pulling too many amps. Which can be caused from insuffecient grounds or a bad starter. Just because the starter kicks over out of the car doesn't show what its doing under a load.
Do you have a ground to the engine block? to the frame?
LilJayV10 is offline   Reply With Quote
Related Topics
Thread Thread Starter Forum Replies Last Post
Starter issues, need shims!???!??? Mick68SS Chevrolet Camaro 1967-2002 3 04-13-2016 11:16 PM
2000 Z28 will only starts 1 out of 20 times = bad starter relay Fred67 General Maintenance & Repairs 0 11-12-2014 09:19 PM
Should I have 12V to starter solenoid wires? JT2000WS6 New LS1 Owners - Newbie Tech 4 07-26-2014 11:40 PM
starter relay is grounded pushrod36 Conversions & Hybrids 6 08-21-2012 10:18 PM
car wont start... sometimes. help!!! firstls1vette Corvette Performance 8 12-27-2011 02:22 AM
Tags
383, chevy, click, due, engine, flooded, gas, hummer, ls1tech, parallel, slowly, start, starter, turns, wouldnt
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
