305 to 350
305 to 350
I have a 89 fourmla with a 305 TBI I Have a good 350 block laying around im wondering if I can swap everything off the 305 block to the 350 and it work? and will I need the pcm for a 350 or what just give me some tips please ill be starting all this when I get my rebuild kit and a new cam and lifters if im missing something let me know plz
That motor should be a roller motor so you are going to have to see if the 350 you have is roller too. Unless you want to go back to a flat tappet setup.
You will have to change the injectors and the knock sensor to do the swap
