Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
CFE Develops 600-cubic-inch Small-block Engine
Old 07-22-2013, 09:59 PM
Suaveat69's Avatar
Default CFE Develops 600-cubic-inch Small-block Engine
http://www.enginelabs.com/news/cfe-d...-block-engine/
Possible to go to 700 cubes!!!
EngineLabs just learned that CFE Racing Products has broken the 600-cubic-inch barrier for small-block Chevy engines.
The Michigan-based company, which specializes in racing cylinder head development, is currently ready to ship the foundation components — cylinder block, cylinder heads and intake manifold — with the necessary dimensions to support a 600ci displacement within the somewhat traditional confines of the 58-year-old SBC platform.
“In all practical purposes, it’s a next-generation small-block,” CFE’s Larry Gadette tells EngineLabs. “It’s what Chevrolet should’ve done 20 years ago.”
The project is so new that information remains limited, and only one photo is available. EngineLabs will update this story as more news is released, hopefully in the coming week.
The new 600ci architecture is an extension of the current big-inch efforts that have escalated in recent years with improved billet-block design and machining techniques. Aftermarket engineers can now enlarge dimensions and map out near perfect geometries and clearances, then program that data into a CNC machine and produce perfectly aligned blocks and cylinder heads.
“We really didn’t start out to develop a 600-incher,” explains Gadette. “We started developing a 572ci engine that was more proportional and conducive to making high-end power.”
The original customer wanted a big-inch engine based off a block with 4.5-inch bore spacing. He already had a crankshaft with a 4.900-inch stroke.
“We started doing some research and thought, if he’s got a 4.900-inch arm, all we need is a little more bore and we’ve got 600 cubic inches,” says Gadette. “It was spawned from that.”
Concluding that a number of markets would salivate over 600ci — which equates to 9.83 liters — CFE moved forward on designing a block with 4.6-inch bore centers and expanding its famed SBX cylinder head to support the wider cylinder locations.
“It’s only .475-inch longer than a traditional small-block,” reports Gadette. “It fits where a small-block fits and it looks like a small block.”
The block, which can ordered with or without water jackets, sports a 4.400-inch bore. When combined with a 4.900-inch-stroke crankshaft, the resulting displacement is 596ci, but it’s possible to poke out the cylinders to 4.500 inches.
“The bore size will support 662ci,” says Gadette. “So it’s almost possible to reach 700!”
Hot rodders have been trying to hog out the small-block Chevy since the ‘70s when they were squeezing 4.0-inch stroker cranks into a stock 400 block to get 434ci. The problem, of course, was rod clearance against the cylinders and camshaft. The aftermarket addressed these issues with newer blocks that raised the cam and provided side clearance.
Displacements continued to creep up, but the next milestone came in 1994 when Sonny Leonard built the first 500ci small block.
560ci is about as big as you can get with the small-block,” says Gadette. “Then you can get a real clumsy engine.”
Blocks stretched out for 4.5-inch bore centers became the norm for big-cube small-blocks when NASCAR approved Chevy’s R07 race engine, which replaced the venerable SB2 engine. For the current generation of 358ci engines, NASCAR allows 4.5-inch bore centers but restricts the maximum bore to 4.185. The extra distance between cylinders give engineers more room to circulate coolant — in other words, no need for siamese cylinders and more durability.
“People don’t realize the SB2 head was developed into a 4.5-inch platform (called the R03 head) but abandoned in favor of the R07,” says Gadette.
The stock deck height on a Chevy small-block is 9.025 inches, but the aftermarket has taken its blocks up to 9.500 inches — with some specialty billet applications going as tall as 10.2 inches. The CFE block is set at 10.0 inches.
“Of course, we could make it 12 inches, if we wanted,” boasts Gadette. “But then you start getting really weird rod-length ratios. At some point you have to call it quits.”
The CFE block retains the standard Chevy bellhousing pattern and 4-bolt steel main caps (stock 400 journal size); plus the familiar horse-collar timing-cover boss/water jacket holes on the front appears similar to the standard small-block. Other features following tradition include standard Chevy engine-mount locations, available distributor accommodation and oil-pan rail dimensions similar to the famed Rocket block, which was an Oldsmobile version of the SBC used in drag racing and provided wider oil pans for stroker clearance and also a raised cam location.
“You can even bolt a regular Chevy water pump to this block,” says Gadette
Outside of the familiar Chevy cues, the CFE block will have .937 lifter bores and will not offer a provision for a mechanical fuel pump. The cam location is “standard big-block plus .400,” and the block will support 55mm roller-cam bearings and 60mm babbit.
CFE stretched out a version of its SBX head, which was developed for the Chevy Pro Stock trucks in the ‘90s, to fit the 4.6 bore centers — a move that opens up considerable airflow possibilities.
“You’ve never been able to get a 2.300 intake in a small-block head. There’s not enough room for it,” says Gadette. “Now there is.”
The 600ci SBX head will hold a 2.300/1.900 combination, which was certainly unheard of just a few years ago. Think about it, a standard 454 big-block Chevy has 2.19/1.88 valves, and the popular Victor Jr. BBC head comes with 2.25/1.90 valves.
CFE will not sell the 600ci components to the general public. A select group of builders has been approved to distribute the engine. They will get only the block, heads and dedicated intake manifold, which can support a variety of carb and fuel-injection setups. The builders then work with their favorite suppliers for the rotating assembly, wet- or dry-sump oiling, induction and accessories.
There are limitations to such a large displacement in a small-block, particularly due to the under-square bore/stroke ratio that complicates frictional losses. However, the total potential for this new engine platform hasn’t been fully explored yet. Gadette says the deck height could be trimmed down to 8.75 inches, giving engine builders for Bonneville-type vehicles or even Pro Mods the potential for an over-square bore/stroke ratio and much higher-revving capabilities — especially with boost.
“It’s such a universal project with implications for performance, such as those looking for the most horsepower from a small-block, or those looking for something cool in a show car,” sums up Gadette. “Whatever direction you want to take it, there’s definitely room for it to be a game changer.”
Old 07-23-2013, 07:01 AM
cambirdracing's Avatar
Here's a picture:
Old 07-27-2013, 09:44 AM
In-Zane Moderator
ZONES89RS's Avatar
Holy crap...
The LS is 510 ci max from aftermarket, wonder when it will catch up?
Old 07-27-2013, 09:58 AM
87silverbullet's Avatar
Originally Posted by ZONES89RS
Holy crap...
A veryyyyyyyyyy long time................
Nobody has even thought of opening up the bore spacing on an LS block yet from 4.400 to 4.5 or like this block 4.6. Plus if you get a 4.5 bore spacing block and get some heads for it they are more likely to be a 15 or 12 degree head so you in essence have an "LS" motor just packaged differently on the outside.
Old 07-27-2013, 06:59 PM
In-Zane Moderator
ZONES89RS's Avatar
Yea, no doubt. I'm no expert on all the dimension capabilities but if a Ls has already gone 510 ci then how far will it go in the future? A 510 has been available for a long time and a sbc only broke 500 cubes 40 years after the sbc was designed. Just do not favor the side by side middle exhaust ports. The individual primaries make larger tube sizes more convenient to allow all those cubes to breathe.
All this sbc 600 cubes is out of anything I could ever pay for, much less a 500 LS. So it is all just a dream for me.
Old 07-27-2013, 07:00 PM
In-Zane Moderator
ZONES89RS's Avatar
And if that pic is the real deal then my exhaust primary complaint is null.
Old 07-28-2013, 10:44 PM
Suaveat69's Avatar
Holy crap...
Not until they go to a 4.5 BS which what I thought the new LT1 was going to be.
Quick Reply: CFE Develops 600-cubic-inch Small-block Engine
