Need Help, Aftermarket speedomoter wiring
For my SBC swap I went with aftermarket gauges and everything is working fine except for the speedometer, It doesn't want to cooperate HAHA. I did a bunch of searching on the t-56 vss (vehicle speed sensor) and still have no luck. Originally I had the tach wired as it shows in the instructions, yellow wire to yellow wire and blue wire to purple wire on the vss and as soon as the car starts up the gauge just bounces all over the place. I read on another thread that one of the wires (doesn't matter which one) on the vss need to be grounded So i removed the purple/blue wire and hooked it to ground as as soon as the motor is running it does the same thing, Just bounces all over the place. Please help me out.... what am I missing??? Thanks
Here are the instructions it came with....
Anybody have any Ideas? I cut and spliced the green wire to ground and only have the purple wire hooked to the speedomoter and it still goes wild when I start it up. I have done alot of wiring on my car and everything is fine except for this... im stumped!!!
