406sbc efi, wanting to turbo charge and your thoughts on my hp
Alright i have a 88 irocz 305tpi iam in the process of building a 400sbc 30 over.. so far i have bought the weiand stealth ram kit, afr 195 heads 65cc, xfi 280 retro fir hydraulic roller cam 280 288 duration @50: 230 236 valve lift 576..eagle rotating assembly all forged mahle pistons, h beam rods 6 inch and a forged crank... what type of horse power could i expect and could i possibly throw a turbo on this set up
Trevor I have a 383 with a set up like your 406. depending on your compression ratio a turbo would work very well as long as your set up doesn't have a lot of compression. I have a cam with specs about the same but build for a turbo. I have a 75mm set up that should push 1,000hp pretty easy, the problem is the stock block. mine is have filled with hard block. if I had to guess I wouldn't push much pass 700hp with a stock block which is what I am aiming at. if you plan to boost it get mls head gaskets and head studs. if you have a factory 4bolt block I would push on it too hard they are pretty good a cracking at the caps. good luck.
