Supercharged sbc build questions
Hello all I'm new to the forums and I need a lot of information on building a supercharged sbc that I plan to put in a 4th gen z28 or ss for street use. I have a 77-79 targetmaster 350 4 bolt main block with 76cc heads and I want to build it and put a weiand 142 on top and I need to know everything between the oil pan and valve covers that I will need to build a good running blown sbc with decent power that can run on pump gas. I need specifics on everything if at all possible...crank, rods, pistons, rings, cam, lifters, pushrods, valves, springs, rockers, timing...literally everything. Thanks in advance
