Please list your SBC/BBC Project here!
Wow, that's pretty impressive Outlaw! Those 275's do help a lot though, and albeit relatively narrow, still look awesome on the car. Now if only I could get that tuck with my 10.5w ET Drags lol
11 & 7 Second Clubs
WOW! There are some big dogs up in here. I am planning on building a 3rd gen with a 355 with Vortec heads, aluminum carb intake and a 200 shot plate kit through a TH350. Just for kicks budget allowing. I already have a motor and trans. They all need to be rebuilt but hey.
Someone needs to do a radical sbc setup! Something radical and fuel injected!! Something rare! A motor like this in a 4th gen would be cool. Someone on this board should do this this winter and keep us posted with installation tips! Wouldn't that be a good idea! I wish I could think of someone that would do this.
Geeeeeeeee..........i wonder who you could be referring to Scott?!?!?!?!?!?! lol. ssshhhh, i'm trying to keep the specs under wraps. but really, thanks. i keep forgetting the details of this beast. i guess i should start to memorize them because i'm working on something right now that could have it completely paid for in the next few weeks, tops!!! don't qoute me on that as ANYTHING can happen! for instance, i just wrecked my wifes minivan 3 days ago on my way home from work i'm in a little hot water for that one. but it's looking pretty good as i believe i just found a buyer for the 9" i just put together the other day. just want to make sure i have the $$$$.
later all,
Dave
later all,
Dave
14 Second Truck Club
My SBC project is a 93 S10 with a 350. Comp 288 roller cam, Trick Flow G2 heads, 750 carb, Holley intake, 700 trans with Midwest 3000 stall, 3.73 rear, its a long list. Trapped as well as 115-116, but couldnt get the 60 fts down, so only ran a 12.7. Might be kicking it to the curb now though and throwing miney at my new truck.
Bickle, would love to but car isn't together yet. Bought the car with the built engine and a t-trim. Fixed some problems, had the AFR's it came with ported, and got a cam better suited to boost. YSi was a last minute upgrade simply for expansion capabilities. Won't push the blower hard with this setup, shortblock probably won't take it. I wanna touch 9's with this engine, and if/when it goes will probably throw in a BBC with the YSi and see what those two will do with 94 octane.
Car is just a toy, it's not designed to race in any certain class or anything. Just wanted a good combo that is fast and grabs attention. Will still cruise it on the weekend and go to shows and such, but it's gotten beyond the point of a legitimate street car.
my 69 nova
I've got a 69 nova i'm building it will have a 422 sbc with all the good stuff all scat bottom end w/ ross forged pistons and also have afr heads and intake with a 150 shot on top and then migth go to a 250 if i got to!!!
72 nova... 355 with forged internals.... has run an 11.17 @ 118 on a 150 shot with a small flat tappet cam.... ready to up the compression to 13 to 1 or so with a .690 solid roller and a 5000 or so stall... I'm 18 and this was my first car.... when i got it, it had nothin in it, for awhile it rode with a worn out 305 and 4.56's, now its becoming a drag project.
#32
72chevy2..........my mph seems to be about 5-6 mph slow for that et. i'm no expert, and maybe someone else might be able to chime in, but depending on you gears, it sounds like you may want to step down a little to get your mph up and perhaps a little off your et too?! what gears do you have now?
later,
Dave
later,
Dave
#33
4.11's with a 4k stall.... it goes 1.50 60' and 7.0 at 97-8 or so in the 1/8th, im not to worried about how it runs now because a lot of things are about to change..... i have 3.73's that were in the car when it ran n/a, and then it ran 11.90's at 110, i think with the cam and pistons i have, the motor isn't gaining much off the nitrous... 340whp/ 390tq through a th350 and 4k stall with a 12bolt n/a and i've never dyno'd on nitrous
#35
just your standard 1st gen nothing special. cert. to 7.50 or slower till '07 ladder bar coilover with a small tire just a nice little slow street car with a bbc soon to have some more cubes over the winter.
#36
Doing a 96 Z28 with All Forged Nitrous ready 355 with a Turbo 400 and a 9 inch...Tubular K Member,A Arms,Torque Arm,All from Alston Chassis Works,rearend from Moser Eng.
355 all forged 12:1 compression diamond Dome Lightweight pistons
6.0 Scat rods
Bulletproof Custom Ground billet Lunati crank
Aluminum AFR Cylinder heads with a Edlbrock Victor JR. Tall intake on it with a 880 Quick Fuel carb on top of it. Big Custom Grind Lazer Cam 600+ lift manley titanium valves,comp roller rockers,comp lifters,comp pushrods.Full MSD ignition Digital 7 box,Crank trigger ignition with crab capdistributor. Hooker Super Comp Coated headers,turbo 400 with 4500 coan stall converter trans brake.
11.0's on motor
Looking for high 9's on a small shot of the good stuff,but will be set up to take a pro fogger 300 shot just for fun!
6.0 Scat rods
11.0's on motor
#38
black 80 trans am. 383 stroker, hypereutectic 9.5/1, steel crank, brodix alum heads, performer rpm intake, 750 holley dp, msd 6al, probillet distributor,blaster 2 coil, 480/480 comp cam, hooker super comps, flowmasters(run open headers at the track), 150 shot sniper kit, th 400, 2600 stall, 3.90 posi, radial ta's 275 65 15, quiksilver ratchet shifter, 6 mpg, 11.90 at 122 mph. i cant wait to get some slicks under it and see what i can really do cuz as it sits it chirps for 300 feet when i hit the button. and im proud to say im 18 and i did it all myself.
#39
1978 Camaro, 409 SBC (.040" over 400), upper steam holes plugged, 10:1 compression, 5.7" rods, KB d-dish hypereutectic pistons, nodular iron crank, Vortec heads, Ram Jet intake, Comp Cams XE274-H cam, roller-tip rockers, late-3rd-gen. serpentine belt setup with custom A.I.R. pump bypass assy. (I made it! :-> ), Stan's tri-y headers, x-piped 2.5" exhaust, Canton road-race oil pan, LM-1 WB O2, 700-R4, Yank converter, 3.42 posi (30-spline), VBC transverse-front-leaf suspension, Baer brakes, Autometer Phantom gauges, other parts to be determined as time goes on.
All in pieces!!!
All in pieces!!!
#40
7 Second Club
Location: Gainesville, Florida # of drag strips runs: ?!?!?
1 Post
My on-going 8-year project is my 1970 Nova. Started with a 307/glide that ran a screeching 17.07 at 80 mph, 1st motor swap was a 355 that got down to an 11.88 @ 111 mph. Current combo is:
383 stroker (actual displacement 388)
Eagle crank and SIR rods
Milodon oil pan and pump
Canfield 195cc heads (unmodified)
Crane solid cam
Edelbrock Victor Jr intake (unmodified)
750 Holley dp hp carb (unmodified)
Hedman headers 1-3/4 headers
Flowmaster american musclecar 3" exhaust system with tailpipes.
Turbo 350 trans with J.W. 3400 stall 10" convertor
12 bolt with Strange 33 spline spool, axles and c-clip eliminators; Richmond 3.73 gears
11:1 compression-pump gas motor. Dyno'd 372 rwhp/492 rwtq.
Driven about 200-300 miles a month, raced 2-3 times a month.
Times and link to pictures are in sig. Car weight with driver ~ 3500 lbs.
Think that's it......
Derek
Crane solid cam
Derek
