Please list your SBC/BBC Project here!
#42
I'm in the middle of a project, 98+ trans am, 427 bbc 60+ roller valvetrain, dart heads, efi, and a vortech blower in the works. 15x12 alumastars in the back, not sure about a tranny, want a manual that can handle the power but still be driveable on the street.
#43
Well, this is a popular place, I'm late, but am new to this site.
We have a 94 S-10 SB
421 Stock Blk
AFR 220s Ported
Roller
T-400
9" 4.86 gear
Mickey T 16.50 x 31 E.T. Streets
Etc....
Got a few passes before the end of the season Best N/A 10.70
Putting a set of old Nascar 18s on this winter, that and get some bugs worked out we're looking for mid 9s N/A.
I'll link to my site, to the vids page and there are some pics and vids.
S-10 Vids
421 Stock Blk
AFR 220s Ported
Roller
T-400
9" 4.86 gear
Etc....
S-10 Vids
#44
70 Chevelle 454 LS-6
Im in the process of having the motor pulled and rebuilding it to stock again. Car has spent the last 10 years in the garage at my current house and probably another 15 at the previous house. My dad was the second owner bought it in 1971 he was nice enough to give it to me.
#45
Getting my project off the ground as we speak.... It started out as a 10 second LT1 355..... Got tired of that and wanted to make in excess of 1200hp and shoot for low 9's to mid 8's.... Decided on a 370" SBC with a big thumper single turbo, dart block, AFR 227's..... That project turned out to be huge on the cash tip seeing as how it was going in a 4th gen and on paper was working out to close to 25-30K (so tack on about 15% for unforseen expenses)..... Called that off due to trying to buy a house instead of messing with cars.......
So now the current project is going the BBC route and either doing an EFI 540 BBC on the bottle and remaining PSCA class legal for three classes or doing an EFI 572 on the bottle.... Wiring is all ripped out of the car and the car is going under the knife to upgrade the cage to 12 point status and rewiring the whole car with a Painless setup. Block is going to be a Dart Big M, Lunati Crank, Oliver rods, JE Pistons..... something relatively streetable but capable of 9 second motor passes and 8 second bottle passes..... I should have pics soon....
#46
My SBC 409
Engine: 400 SBC ID# 330817/14y139664/ T0508CSU
(4.125 bore X 3.750 stroke) after .040 bore (4.165 bore x 3.75 stroke =409)
Deck Plate Bored, Mains Align Honed, Block Deck .002, Deck Plug Holes & Tap w/3/16 Holes, Starter Bolt Drilled, Front Three Gallery Plugs Tap for ¼ Pipe Plugs.
Crank: Scat 4340 Crank 3.750 6.00, Internally Balance,
Part# 4-400-3750-6000
Bearing: Clevite– MS1038H Mains and CB663H Rods
Piston: Wiseco Pistons, .040 over, 5.4cc; 430 grams, Part# PT020H4
Rods: Eagle ESP 4340 H-Rods 6.0, Part# CRS6000B3D
Block: Zero Deck: 0.002
Compression Ratio: Static-10:48 Dynamic-8:27
Cam: Grind: Solid Lunati/ (Recommended by Harold Brookshire)
280/284F10 .525/.530 Lift, 247/251@.050, 159/162 at .200, .560/.565 valve lift(1.6), 2500-7000 RPM, Advance Cam 4* Degrees as Per Harold, .026" Valve Lash Hot, Adjustment Range: .018" to .030" Hot.
Heads: AFR 195 Part# 1035 w/23º valve angle, 74cc, drilled steam holes
Springs for Solid Cam- 130-135 Seat and 325-330 Open 280/284F10
Head Gasket: Fel-Pro-1014 / .039 in. compressed thickness, 4.200 in. bore, 9.0 cc compressed volume
Intake: Edelbrock RPM #7101
Carb: Speed Demon 750
Rear End Gear: 3:73
Transmission: Pro-Built Street/Strip 700R4
Stall Converter: A.C.T. 3000 Stall
Exhaust: Hooker Super Comp headers 1 5/8 Headers part # 2460-1 ceramic coated;
Hooker Super Competition high flow cat-back exhaust system, Intermediate pipe: 3 in.
* Tail pipe diameter: 2 1/2 in.
* Dual tail pipes out the rear under the bumper
Here is the pics and Dyno Results:
http://community.webshots.com/user/dtl504
Rear End Gear: 3:73
#47
SBC 408 PARTS and PRICES
MANUFACTURE DESCRIPTION PART# PRICE
AFR Heads 195cc AFR-1036 $1,425.00
ARP Main Studs ARP-234-5501 $51.95
Head Bolts ARP-134-3701 $58.95
Oil Pump Stud ARP-230-7002 $6.50
Oil Pump Shaft ARP-134-7901 $13.95
Fuel Pump Pushrod ARP-134-8701 $14.95
Cam Bolt Kits ARP-134-1001 $3.95
BARRY GRANT SPEED DEMON 750 1402010 $355.00
CLEVITE Main Bearing MS1038H $55.00
Rod Bearing 8-CB663H $55.00
CLOYES True Roller Timing Chain CLO-9-3100 $60.09
CRANE Energizer Roller Rocker CRN-11744-16 $132.50
EAGLE H-Beam Rods CRS6000B3D $335.09
EDELBROCK Elite Air Cleaner EDL-4207 $49.88
Valve Covers Tall w/ Script EDL-4249 $69.95
ELGIN Solid Lifters VT1992-16 $50.00
FEDERAL MOGUL Cam Bearings 1235M $19.00
FEL-PRO Head Gasket FPP-1014 (2x) $63.90
Intake Gasket FPP-1205 $13.95
Rear Main Seal Align Bored FPP-2909 $18.95
HOLLEY Carburetors 750 VAC. SEC. HLY-0-3310S $249.95
Fuel Regulator HLY- 501 $26.00
LUNATI Flat Tappet Mechanical LUN-280/284F10 $183.71
Valve Springs LUN-73124 $92.00
MILODON Oil Pump Pick-Up Screen MIL-18311 $34.95
Milodon Street/Strip Oil Pans MIL-30900 $123.49
Diamond Stripper Windage Tray MIL-32250 $74.95
Lifter Valley Screen Kits MIL-23150 $15.95
Oil Pan Baffle MIL-32500 $5.25
MELLING Oil Pump MEL-M55 $15.95
MR. GASKET Oil Pump High Press Spring MRG-26 $3.95
PIONEER Brass Freeze Plugs SBC 400 $14.95
Harmonic Balancer 8" Int.Bal. PIO-872003 $95.88
Flexplate 168 tooth FRA-100 $34.50
RUSSELL Clear Fuel Filter RUS-645470 $14.88
SCAT 4340 Forge Crankshaft 4-400-3750-6000 $490.00
SUMMIT Fuel Pressure Guage SUM-800115 $19.95
WISECO Pro Tru Forged Pistons PT020H4 (0.040) $419.00
TOTAL COST $4,768.87
Engine Parts Total $4,768.87
Engine Machine Work Total $954.00
$5,722.87
$5,722.87
#48
Just found you guys.I've been looking for some bbc experts.I'm just starting to prep a 95
Camaro for a 402 running at a local 1/8 mile.Can anyone tell me if gen V heads will fit the older blocks.Do the gen V heads flow any better?
Thanks
Thanks
#49
Maxxum,
May I ask why you would run such a small motor?
I mean if you are going to pay for the extra weight, why not run some cubic inches?
I mean a 406 sm. blk is bigger, lighter and both built equally will outrun the 402 fat blk.
#52
Procharged 70 Chevelle SS454
My combo is a 70 Chevelle with a 454 and ATI Procharger. Pump gas friendly 10 second car. Nothing fancy in the engine but the D1 makes up for it.
Walt
http://www.personal.kent.edu/~wbainey/CHEVELLE.htm
Walt
#53
71 rs – Z-28 BBRSZ
It has a hotchkis front and back hollow sway bars,
Competition engineering front and back springs, stock ride height because nj roads are a mess
Comp. Engineering welded in frame connectors
Bilstein shocks front and back
Polyurethane bushings everywhere, body mounts, front and back sysp. Ect.
9” curry ford rear, black powder coated, 3.50 gears, 31 spline posi. Curry h.d. Axels
17 x 9 ½ front 17 x 11 back TT 2’s 6” backspacing on back.
yoakohama 032r. dot legal road race tires. 275/40/17 f. 315/35/17 b.
rear fender lip’s cut off, epoxy filled between inner and outer fender, some selective
hammering of high spot’s near rear shock mount locations.
Front fenders w/ rolled fender lip.
Baer brake kit, came w/ package deal w/ curry rear.
I thing it a pro track kit. W/ upgraded rotors
2 piece-floating rotors cross-drilled and slotted. 13” fnt. 12.5 bk
Red anodized inner rotor hats.
Hand bent brake lines, front to back bias adj. ****
Blown up t.c.i. 700r4 trans w/ stock ‘u’ shifter w/ detent plate cut
to lock out each gear.
Double decker trans cooler w/ electric fan
balanced and blueprinted
427ci 30 over w/ 11 to 1 comp. 1970 L-72 big block
L-88 aluminum heads, ported and polished
(want to upgrade to AFR’s)
Heat coated Hooker comp headers 2” primary, 3 ½” collectors
Custom made Mr. Gas x pipe to flowmaster’s
930 cfm barry grant carb , 580 hyd. Comp cam.
Gold comp. Roller rockers
holly fuel pump, ½” alum fuel line, holly regulator
m.s.d. Ignition, & distributor, 8.5 mm wires custom cut
Optima battery in trunk.
Motion valve covers, and air cleaner. w/ custom
Made K&N filter element
Autometer tack, oil temp, water, vac. Gauges
Black leather 96 corvette bucket seats.
Deluxe rs woodgrain interior. W/ center counsel
No stereo, no heat, no ac.
Car is 98% done, just need a new trans and roll bar.
It was shelved last year due to the exurbanite about of money the TTSSZ sucked up.
I’ve had car for 8 years, frame up resto for 5 years
Replaced everything but the motor and the paint. (black cherry, flawless)
Paid $5500 for it, got a grate deal. The guy’s wife was pregnant and wanted a house
And his parents wanted it out of their driveway.
It was set up for drag racing, (slicks, shinnies, 5.38 rear, stripped down.) I converted it for the road.
The seller and his brother built it over 10 years and put $22,000 into it.
I have about $25,000 more into it. It’s a labor of love and I will keep it for ever.
I am the biggest camaro fan, I still have my #3 camaro a.f.x. car I got when I was 3.
I also built a twin turbo 2002 blue SS to go with the 71.
TTSSZ Twin Turbo Super Sport Z-28 572rwhp/550rwtk
BBRSZ Big Block Rally Sport Z-28 550rwhp/ 590rwtk (on juice)
#54
i am working on a '69 camaro project which has a lot of rust. i am doing the body work myself for financial purposes (its hard to get a good autobody person to do it for cheap). we got the car in november of 2003 and it is slowly coming together as it has a lot of rust and i have found more as i uncovered things. for the motor, my dad and i have plans to put a 540 big block in it but we will see when we get to buying motor parts for it.
#57
Originally Posted by Jewmont3
Starting to work on an LS1/T56 swap into my 95 GMC sierra...
-Mike
-Mike
no offense Mike, but wrong forum. this is about putting old school motors in newer cars and the technical matters about those motors. like the sbc i'm putting in my '98 Camaro.
later,
Dave
#58
[QUOTE=Jewmont3]Starting to work on an LS1/T56 swap into my 95 GMC sierra...
Mike,
What year LS1 are you swapping in? Are you grabbing ECU, Wiring and all? Start a new link with your build. I have a 95 that'll get and LS1 in a few years.
Walt
Mike,
Walt
#59
427 sbc
Some nice rides in here for sure.
Just stripped my 95 camaro for a diet. Was running it full weight with a hydraulic roller 383 and T56 on juice for a best of 10.87 @ 128mph. Now, built a 427 sbc with a Motown block, belt drive distributor, and a FAST system. Re-doing the 9" with a spool and T56 with Viper internals.
Oh ya, the cool part. Heads are SB2.2 ported out quite nicely. Fogger system will be added later after I play NA for a while.
I could take pics, but who hasn't seen a black 95 body stripped down to absolutely nothing. Here's a mockup of the heads though on the old LT1 block.
#60
1971 El Camino, plans are changing right now. Had originally planned for 482 ci with LT1 T56. Have changed to 496 ci alky injected motor with TH400 and 4.88 12 bolt. "Street" car that should run low 6s high 5s 1/8 mile times.
