1972 400 sbc t56 swap flywheel question
im looking to put a 97 t56 behind my 13.5.1 compression 406 motor. the motor is a pre 86 two piece main seal block. im just asking if anyone knows of a flywheel i can use for the conversion. cause the 168 flywheel i tried using hits the bottom half of the bellhousing. if anyone has done this swap. give me a holler
thanks
joe
thanks
joe
I'm sure you already know this, but you should be sure you get a flywheel for a 400 because it is externally balanced (on the harmonic balancer and the flywheel), as opposed to internally balanced like a 350, 327, 307, etc.
hello
does any one know the part number for the fly wheel. I am doing a 406 swap in my 1991 camaro and I can't find a fly wheel that will work with my t 56. And the clutch I am using. will some one please let me know.
