Need a 350 - LS1TECH
Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
Need a 350
Thread Tools Search this Thread
Old 07-15-2005, 01:55 PM   #1
jessebuickguy's Avatar
Default Need a 350
Hello I need to know were I can get a good CHEAP 5.7 block to replace my 5.0 Tuned Port Injection block, in my 1991 Z. I think that I can use the Tuned port intake, starter,distributor,accesories, except for the injectors on the 350. Do I have to replace the pcm completely, and get a 5.7pcm. Or can I just replace the chip. Basically i just want a 350 tuned port injection engine under my hood. I will greatly appreciate any advice. Thanks
jessebuickguy is offline   Reply With Quote
Old 07-15-2005, 02:27 PM   #2
Muffracing's Avatar
A '86- '95 carb engine will let you bolt the intake right on. Throttle body engines use different heads, but will bolt the intake on the same. If you get an older engine you need to slot the center four holes on the intake, because gm changed the angle of the bolts on the newer heads. I think you need 350 injectors too. Maybe some one else can confirm that.
Muffracing is offline   Reply With Quote
Old 07-22-2005, 10:53 PM   #3
3rdgenguy's Avatar
Quote:
yes bigger injectors are a must
3rdgenguy is offline   Reply With Quote
Old 07-26-2005, 01:28 AM   #4
sidewayz28's Avatar
i wouldnt even bother with a TPI.....i would just buy a cheapy carbed 350...
sidewayz28 is offline   Reply With Quote
Related Topics
Thread Thread Starter Forum Replies Last Post
Will they fit? BigEd_72455 Generation III Internal Engine 2 07-09-2016 08:29 PM
Need help with diagnosing a high idle 1976CamaroGuy PCM Diagnostics & Tuning 24 07-01-2015 07:47 PM
5.7 to 383 tuning question drptop70ss LT1-LT4 Modifications 84 03-24-2015 05:54 PM
Are 5.3/5.7/6.0 PCM's the same? 98 WS6 PCM Diagnostics & Tuning 15 03-10-2015 08:44 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
